Sold/Expired GM Dana 60 front axle with Jana 76 kit(with RCV inner shafts) SOLD 2/27/16.
CHASMAN9
Hardline OG Administrator
Staff member
128
Chelsea, Al
GM Dana 60 front housing that has the Jana 76 kit that just was removed from my Heart Attack buggy. It comes with a new Dana 70 Yukon 35 spline spool that was running 4:10 gears and was covered by a heavy duty chrome diff cover and diff guard. It has the 4 link tabs already to be bolted up too as well as the bump stop pads are already in place. This housing also comes with RCV inner shafts which is about equal to what I am asking for the whole thing. There is nothing wrong with this unit, just upgraded to a 14 bolt. For an additional $450 I have a new Detroit locker that was used for about a total of less than a minute running time. Pics to follow.
Housing is located in Chicamauga Ga, south of Chattanooga, Tn
$[size=10pt]1200[/size]
Gregg
Chelsea, Al 35043
205-482-5628 text or call
Re: GM Dana 60 front axle with Jana 76 kit(with RCV inner shafts)
BTT
Dayuum! I know someone that coulda saved an assload buying this! Nice! Glws.
Whatcha got to replace it sir?
Got me a little old 14 bolt in it's place now, that little old Mouse motor plays hell on them parts. thumb.gif
From the pages of Jantz Engineering
Jana 76
To start with there are several versions of D70's (70, 70U, 70HD, 70B, etc.) but they all use the same ring & ring & pinion, The differences are just bigger bearings and bigger castings and different housing dimensions, depending on gear ratio. All the commercially (desirable) Dana 70 high and low gear sets can be fitted into Dana 60's with our Jana Hybrid kits.
1st. We have to get the larger gear in the housing. Since the D70 ring gear is 3/4" larger in diameter the than the D60 ring gear, there needs to be 3/8" clearance around the D60 ring gear in the housing to clear the D70 gear, most 60 housings are cast with approximately 1/4" clearance, so only an 1/8" of grinding in a few spots is necessary.
2nd. We have to get the pinion in and it needs to go roughly 3/8" farther out from the center line of the ring gear. To do this, an adapter pinion head bearing is used setting the pinion depth deeper into the bore. This then moves the tail bearing, seal & yoke farther out but luckily there is still room to get the parts in with the proper spacers, shims and adapter rings.
3rd. The 70 Pinion gear is also a bit larger thus the carrier needs to be moved away from the new pinion gear about a 1/16" for clearance. Again a narrowed adapter bearing is used to accomplish this without any loss in bearing load carrying capacity.
Benefits:
Your Ring & Pinion is 33% stronger with no loss of ground clearance.
Dana rates the 60 @ 6000 Ft-lbs maximum momentary output torque. 35 spl HD.
Dana rates the 70 @ 8000 Ft-lbs maximum momentary output torque. Non HD.
That's a 2000 ft-lb increase in capacity.
Also, if you have alloy axles, then your current weak link is the most difficult and expensive part to repair ie: the ring & pinion.
If you compare the cost of a Dana 70 gear set and carrier/locker to the cost of a Dana 60 gear set and carrier/locker, you will find they are within few bucks of each other. Now if you’re going do this right then you need a new installation and bearing kit as well, this is going set you back about $150 more than a standard bearing kit.
We of course can sell you everything necessary for this hybrid conversion. But there are also plenty of wrecking yard finds for the cost conscious. The question I get the most is: “Will this or that Dana 70 carrier I find work with the kit"? The answer is that they all will work, some easier than others. To keep this simple let’s make the following assumption, you will be using gears 4.56* or up numerically. Now because of the larger pinion diameter the carrier needs to be a bit farther away from the pinion to get the backlash correct. There are 2 basic series of carriers for the 70s. The ones for 4.10 & down, and the ones for 4.56 & UP. The offset of the carriers is 1/8" but we only need to move about 1/16". The Narrowed carrier bearing supplied allows us to do this as follows:
If you have a 4.56 & Down carrier, it will be to close, move it away (Inst Narrow bearing on Ring gear side). If you have a 4.10 & up carrier, it will be to far away, move it closer (Inst Narrow bearing on Pinion gear side) The prior Cost benefit analysis was based on starting with a bare housing, Now many folk will already have a lot invested into their Dana 60 already when bam! crunch! the ring & pinion breaks! Your 1st thought will now be "I need a 76" your next thought may be "I have a bunch of money already in my Locker, spool, ARB etc .......hummmm....... is there any way I can use my current unit with the 70 gear set." The answer is yes In some cases, but it takes some machine work. The ring gear bolt pattern is different and the ring gear register is also different. We can plug your current ring gear holes and redrill the new bolt pattern, along with supplying a press on concentric adapter ring. $200-300. If you have an ARB we change out part of the case with 70 ARB parts & do a little machine work.
Alright, time to move this.
$1200
Re: GM Dana 60 front axle with Jana 76 kit(with RCV inner shafts) Reduced price
Time to move this unit. Don't need it sitting around collecting dust on them RCV shafts and spool.
[size=10pt][size=10pt][size=10pt]$1000
[/size][/size][/size]
:eek: :eek: :eek:
Damit I need this so badly. Some one is committing robbery getting this for a grand.
Makes me want to buy it just because :****:
:woot: why havent you locals bought this ?! SHEIOT thats a steal !! :eek:
U sneaky Lil devil! Can't wait to see the new axle! Wish I had the money for this.. Not cause I break **** all the time (not axles anyways) .. Only so I could ride around hollerin at random folks as I drive by "JANA 76 AXLE UP THERE, ****S CUUUUUSSSTOOMM SON". And then do a big burn out ... Burn out being spinning the tires in this case. :smoke:
U ain't right haha
Would chasman be coming through southern middle tn any time soon?
HAHA, I'll make vroom vroom noises for you! lmao Kush
whiskeymakin said:
U ain't right haha
It's already in Tn, or somewhere near there in Chickamauga something or rather. Lol. It's at Nick's shop and can be at AOP this weekend if you want? :dunno: He's racing there and can bring it with him
My weekend looks pretty crazy. I will call if it looks better
Sold. Thanks Josh and post up some pictures of your build. :dblthumb:
