Sold/Expired GM DRW Dana60 hubs converted to SRW 350 pair shipped
EddieHall
Pensacola
I've been converting these hubs for a while. I've had alot of positive feedback on them ppl like my turned down hubs better then the factory hubs. I hav alot of time turning them down.I taper them machine the wheel mounting ring to press on its self it under a load then back on the lathe. I run them on the lathe at hi speeds to make sure they true.there 1/4 or .250 thicker at the lockout mount. when u lay them side by side with factory hubs there almost the same other then mine r thicker were u need it and they don't run out like factory..tell me what u think Eddie 8503824209
Are these exactly the same dimensions as the single rear wheel hubs like if you were going to convert to half-ton brakes from one ton brakes?
Yes and yes the id & od an everything else is the same as a factory SRW hub I pulled all my measurements off factory u can use the 3/4 ton to rotor and calipers with tmr brackets thats within running
*****in! I happened across a screamin deal when I swapped mine out, but this could make a lot of peoples life much easier.
I had my hubs turned down like this about 4yrs ago. I like the fact that there a little thicker around the lock out/ drive flange area. Don't know if it helps or hurts it but thicker equals stronger to me.
It makes them stronger. i can turn them to the same OD but I figure it's just extra material and it's not n the way so use it
Bump. RIP Baton Rouge PD officer's !!!!!!! may God bless all police officer's and first responders..we stand in front and with you, thanks for all that you do.
