High idle ??
TOPWOP
EAST
Ok so i have an 88 xj i was told that the tps sensor was not working. so i replaced the tps sensor and the idle control sensor also. Well it worked for starting up but as it runs or warms up the idle comes up with it. (it comes up to about 2000)
Any ideas??thanks
4.OL im guessing. try cleaning the tbody plate with a old tooth or teeth brush. depending on where you are from and pull the idle air control valve out and clean inspect or replace. depending on fundage... this is kinda a comon problem.. and let me know if that works..
:haha:
sorry...i have nothing else to offer except:haha:
set ? please explain
but rember it idles about 800 when i start it cold and then when it runs for only a min or less it starts reving up to about 2000
so the tps and the idle control. are in there limits. so i was also thinking could it be the fule pressure regulator. dont they act up as then get hot.or cold ??
