Sold/Expired hp60 and toyota elocker
cruiserfj
Member
2004 high pinion dana 60 out of a super duty ford. complete hub to hub. had 52k miles when pulled. SOLD
parts to fit the hp60
pair of 35spline chromo stubs for unit bearings one clearanced for 50' steering $170
pair of warn premium lock outs to go on unit bearings 30 spline $75
pair of 6 lug unit bearings (have some surface rust) still seem smooth $100 obo
willwood rotors and calipers and brackets to fit. $450 obo
3 currie aluminum Knuckles to fit a BJ 60 (one has been repaired) $550 obo
also have a Toyota Elocker rear end complete out of a 98 4runner. has yukon chromod 5.29s with a solid pinion spacer and set up by ZUK, (elocker motor was broken. has been converted to a manual lever on the diff to lock in and out. $650 obo
trade for parts to link my 4runner or 10' coil overs or 2.5 air shocks
all located in Fayetteville AR.
I believe the stubs are yukon but not sure I got them used.
no pics of the elocker I can get some soon. anything you are wanting pics of? just looks like a rear end with the elocker motor taken off and a small lever added to lock in and out. still has all the brackets from the 4 link that was on the 4runner.
I am more interested in the elocker diff. Is the conversion home made or is it a kit?
it is home made I will try to get some pics tonight. you could still bolt a elocker motor to it if you wanted.
Thanks I was looking for just a diff as this would need to be shipped to SoCal.
Rear diff ring and pinion have been cryo'd. Great setup for someone. ZUK is the best in the business at Toyota gear setups.
