install of gears ?
GREIWEDILLON
Graham, WA
I have a used carrier and pinion that needs to be installed in my dana 44 chevy front axle. How much would someone charge to do the install ? I understand it has to be shimmed so thats why I am asking if someone on here knows what they are doing can do it. you can write me on here or call or text me day or night at 253-691-7060 If you can do it what parts should i order if I do not have to do a full master install kit then I would rather not the bearings that are on it are still good.
Thanks,
Dillon
Do you have the ring gear that matches the pinion?
I've always used full install kits with new bearings, better to spend a little more money the first time rather than try to cheap out and have to buy all the stuff anyways... and pay someone to set it up again. Also your hassle on pulling the axle out again.
