Pringlefab
- Joined
- Dec 31, 2012
- Messages
- 74
1997 Jeep TJ Buggy with ***le
Drivetrain:
- Stock 6 Cyl
- 5 Speed Trans
- 231 t-case with SYE Eliminator kit
Front Axle:
Ford Dana 60 High Pinion
4.11 Gears with Spool
PSC Double Ended Ram
BTF Truss
35 Spline Inner with 30 spline Outers
Dual Piston Calipers
14" Fox Coilovers
Rear Axle:
Sterling 10.5
35 Spline axles
Disc Brakes
BTF Truss
16" King Coilovers
**Note - the shocks and bypasses are not included. They are being used for another project
Chassis:
2" DOM Chassis with a small section of TJ Frame
4 link front and rear
PRP Limit straps
20 Gallon Fuel Cell
Battery Disconnect
Yellow Top Battery
Ron Davis Radiator
8000lb winch with rope
Suspension Seats with 5 point Harnesses
WHeels/tires:
(5) Raceline Monster Beadlocks - 17" x 9.5"
(6) BFG KRT-B Sticky Tires - One is not mounted and a small hole was vulcanized in the sidewall - 40-50% tread life left
This buggy is a blast to drive. I am getting back into another race rig or I would keep this one. The fenders that are in some of the pictures are not on it any longer. I still have the rear ones but it made the body to wide so I took them off. The front fiberglass baja style didn't last long in the trees.
$12,500
Located in Plano, TX (North Dallas)
Chip - 817.774.3667
Drivetrain:
- Stock 6 Cyl
- 5 Speed Trans
Front Axle:
BTF Truss
14" Fox Coilovers
Rear Axle:
Sterling 10.5
35 Spline axles
Disc Brakes
BTF Truss
16" King Coilovers
Chassis:
PRP Limit straps
20 Gallon Fuel Cell
Battery Disconnect
Yellow Top Battery
Ron Davis Radiator
WHeels/tires:
$12,500
Chip - 817.774.3667
