Sold/Expired Jeep tj crawler on tons
Heintz57
Member
2001 Jeep Wrangler
4.0 5 speed np231 with a sye
4 linked front and rear with psc full hydro steering
Front dana 60 high pinion ford with artec truss king coils
14 bolt rear trussed disc brake conversion king coils
Locked with 4.56 gears
39.5 irocks on 15.5 recentered h1 wheels with just a few runs on them. One bead lock leaks down with time
Front and rear bumpers will be included if they are not installed before it sells
Fuel cell behind the rear seat running the factory pump and sending unit
Led headlights and taillights
Frame has been plated and it has a custom tube mount for the tcase
Jeep flat goes but it's time to get rid of some toys and finish others
Call or txt 615-972-1075
Located in Joelton Tn which is 30 mins north of Nashville
$12,000 obo
Does the front have dodge hubs on it or did ford have external lockouts at some point?
He probably searched for a set of gm or dodge outers in order to get the more common 12in stub shafts or convert to the 1/2 ton brakes.
why is some of the frame silver and some parts black?
Same thing with the rear axle?
Axles were set up when I got it but yes changed over dodge outers with gm brakes. I hadn't painted the rest of the frame black in the pics. Jeep is sold btw
