Sold/Expired jeep xj dana 30 and 35
scrowexj
Danville, Alabama
I have a dana 30 front come from a 91 xj gears are all good pulled out of my jeep and put newer axle under it . I think the vacuum actuator may be bad or my jeep was not pulling enough vacuum one not really sure . it would work sometimes and some it wouldn't . its missing 1 rotor and both calipers but I believe I have some I could throw in with it or for core anyways. I can pull covers and take picts if needed I think its a high pinion but will have to look and check agin also have a Yukon actuator block off plate ill throw in with it also if you wanted to put a long side shaft in it to make it single passenger axle shaft
And have a dana 35c rear axle come from same jeep.ring and pinion are all good . it HAS been welded but only has 3 rides on it since. Just done a rear disk conversion on a 8.25 and put in in jeep so I need these out of the way maybe someone else can use it. can pull cover and take pict also.
will take 150 obo on front
150 for the rear
or together for 250
will trade just need them gone there both OBO
located in Danville,al around 20 min south of Decatur and can possibly meet or deliver if needed
call / text 256 612 0six37
