hamsmotorsports
Member
- Joined
- Oct 19, 2011
- Messages
- 5
Jeep yj buggy. $12000
350 tbi fuel injection mild cam and flat top pistons.
TH350 trans full manual valve body alto red clutches. Dual trans coolers, B&M shifter with custom gate plate.
Atlas 2 3.8 with heavy duty 32 spline front output. 1410 u bolt yokes front and rear, TMR customs tail shaft support.
Gm Dana 60 front 538 gear full spool USA chromo inner and outer shafts with Yukon super joints 35 spline drive flanges. Ballistic high steer arms with bronz upper king pin bushings. Under cover fab works full truss psc double end ram steering.
14 bolt rear 538 full spool. TMR 15 bolt shave kit. Artec truss. Disc brake conversion.
16" air shocks front and rear. Sway a way fronts. Profender rears. Rock equipment rear sway bar. Double triangulated four link front and rear from ruffstuff. All 1.25" Heims. All 2" .250 dom links.
5 42x15x16.5 swamper tsl the four on truck are grooved spair is brand new. Mounted on H1 double bead locks
Chassis was cut off behind front seats. All tube is 1.75x.120 DOM
This thing is no show jeep. It has been wheeled hard and it shows. That Said it is turn key ready to go to any wheeling spot in the country.
Most that would want to buy this would have to re mount the seats to drive it. They are solid mounted for me 6'8" tall.
Asking $12000. Will entertain trades of mild built jeep and cash. Don't need to sell so not giving it away. Can help with delivery. Any questions or specific pictures just ask.
