Sold/Expired JK Heavy duty Stock Track Bar Bracket
Barnes 4wd
JK Heavy duty Stock Track Bar Bracket​
This heavy duty bracket address all the short falls of the factory JK track bar bracket and will fit the Dana 30 or the Dana 44. First we make it out of ¼” 100,000 tensile strength steel that will not bend like the factory bracket. The bracket also increases your ground clearance by allowing you to rotate the steering dampener to the top side of the tie rod. If your lift kit included an adjustable track bar and mounted to the factory bracket this is the bracket that you should use. This bracket can be used with or without our JK axle truss.
