Sold/Expired K5 Blazer with one ton axles 4 speed standard
Sport454
Has a built small block, not sure on internals but can tell it has a decent cam and it has an aluminum intake with a Truck Avenger Holley carburetor, Doug Thorley headers, aluminum valve covers, aluminum finned oil pan, aluminum timing chain cover, aftermarket harmonic balancer and aluminum pulleys. Runs great, good oil pressure, no smoke BUT does have a ticking sound that really sounds like it could be a wrist pin. I pulled the valve covers and ran the valves with no change to the ticking sound. (It also has stock rockers).
SM465 granny low 4 speed.
NP205 transfer case.
Dana 60 front (open) 4.10 gears.
GM Corporate 14 bolt FF rear welded with 4.10 gears.
Rock Ram hydraulic assist steering.
39.5 TSL Super Swampers
4" suspension 3" body lift
New fuel tank.
Twin electric fans
Clean interior.
New exhaust with what appear to be Flowmaster knock offs and big goofy exhaust tips. Which go well with the big goofy front bumper. Lol
Add on roll cage in the back.
Receiver hitch
5000.00 OBO trades welcome.
www.MudStruck.com
Re: 1975 K5 Blazer
Sure its not a 1976? I might be wrong, but thought all 75's were full removable tops.
Re: 1975 K5 Blazer
I did too. This one has a 75 ***le and the numbers match. So I'm not sure what's up unless someone swapped a later model body on it.
www.MudStruck.com
Re: 1975 K5 Blazer
Yeah 73 through 75 had the full top in that body style. That's got to be a 76 or newer.
Re: 1975 K5 Blazer
I'm thinking someone replaced the body it still has the wiper switch in the dash and has square fuses.
www.MudStruck.com
Re: 1975 K5 Blazer
Thank you for the information
www.MudStruck.com
