Sold/Expired Keeping it
slim1968
1
traded on this buggy and cant fit good gonna try to SALE OR TRADE before have to cut it up
Fuel injected Gm 350 chevrolet,has angle plug double hump heads with bolt holes,roller rockers
Chassis is all dom besides under the cab,under the cab is 2x3.
New rod,main,cam bearings with new rings. had heads reworked, Trans rebuilt, and a new JB Fab Cable Twin Stick.
Its a .040 over dome top motor X rods *i think*. Crank was turned .010. Heads intake and block have been decked. Also all new seals etc. Pete jackson quiet gear drive, vette water pump bout brand new. 1.6 roller rockers and hardened push rods, baffled oil pan, Holley fuel pump
2.02 1.60 valves. . Has fox air shocks
Newly rebuilt GM 60 front welded with chromoly outters and chromoly drive flanges with new artek truss/skid plate.
14 bolt rear with factory detroit locker. 4:56 gears
Drive shaft built by Chattanooga Driveline with lifetime warranty, strongest, smallest he could build.
Fresh rebuilt Th350 with GM np205 w/new seals and bearings twin sticked,trans has good clutches.
3/4" and 5/8" heims all moving and suspension parts have grade 8 bolts
40x16x17 New Super Swampers (2rides) on New 17" Marsh Racing Beadlocks w/rock Rings 2 rides
All new spicer u joints
Disc brakes all the way around with stainless steel lines and Wilwood pedal assembly.
Kirkey seats with covers, g force harnesses
Custom headers
Custom aluminum fuel cell
Custom aluminum radiator equivalent to a 4 core with big fan, dont remember cfm's but does its job never gets hot
Floor pans and dash
Full PSC 2.75" hydraulic steering, Eaton orbital and fittings, new lines, 8" double ended ram with High Steer and Double shear kit from Artek Mounted on there skid pan all 2 rides
Sidewinder shifter.
Lots of other extras.
TRANS JUST BEEN BUILT AND IS NOT RIGHT
Located 60 miles from memphis tn in ashland ms. Got 3 rides want to make in oct $15,000 last drop gonna start cutting it up next week
Re: TUBE BUGGY/bouncer $17,500 or TRADE cant fit
Pics comn call or text 662-224-4848
Couple pics for you
Pic
Re: TUBE BUGGY/bouncer $17,500 or TRADE cant fit $16,500
now $16,500 possible trade on toyota buggy
Trade you my ftoy and cash ? Sent you a pm
what do you mean by trans just been built but is not right ???
acts like pump going bad
Re: TUBE BUGGY/bouncer $17,500 or TRADE cant fit $16,500 LAST DROP $15,000
Offer still stands
Open to trades?
Seems like a great deal. So the transmission is the only thing wrong with this buggy?
Yes can still drive until I cut up to get leg room or pull trans but got to make that call soon
