Sold/Expired King Shocks & Coil Overs from CCOR
CCOR
706-559-9609
Athens, GA
[size=10pt][size=10pt][size=10pt][size=10pt]King Smoothie's
CALL 706-207-4140
Designed for use with existing coils, torsion bars or leaf springs, King smooth body shocks are built from the same materials and to the same tolerances as our top of the line race shocks. Their smooth good looks are matched by their smooth performance. These versatile shocks can be built in several configurations to fit your needs and are fully serviceable and adjustable with simple tools. Available with a remote reservoir, piggyback reservoir or pure emulsion we can build shocks to fit whatever and wherever you drive. A set of King, smooth body shocks, are all you need to make your suspension perform to its full potential.
Smoothie Piggy Back Remote Reservoir Emulsion
Part# Description Type Details Weight Compressed length Extended length
PR2006-SSNR 2.0x 6" Smoothie Emulsion 6.00 13.000 19.000
PR2008-SSNR 2.0x 8" Smoothie Emulsion 6.50 15.000 23.000
PR2010-SSNR 2.0x10" Smoothie Emulsion 7.00 17.050 27.050
PR2012-SSNR 2.0x12" Smoothie Emulsion 8.00 19.585 31.585
PR2014-SSNR 2.0x14" Smoothie Emulsion 9.00 21.585 35.585
PR2016-SSNR 2.0x16" Smoothie Emulsion 10.00 23.600 39.500
PR2006-SS 2.0x 6" Smoothie Hose Reservoir 7.50 13.000 19.000
PR2008-SS 2.0x 8" Smoothie Hose Reservoir 8.00 15.000 23.000
PR2010-SS 2.0x10" Smoothie Hose Reservoir 9.50 17.050 27.050
PR2012-SS 2.0x12" Smoothie Hose Reservoir 10.50 19.585 31.585
PR2014-SS 2.0x14" Smoothie Hose Reservoir 11.50 21.585 35.585
PR2016-SS 2.0x16" Smoothie Hose Reservoir 13.00 23.600 39.500
PR2006-SSPB 2.0x 6" Smoothie Piggyback Reservoir 13.000 19.000
PR2008-SSPB 2.0x 8" Smoothie Piggyback Reservoir 15.000 23.000
PR2010-SSPB 2.0x10" Smoothie Piggyback Reservoir 17.050 27.050
PR2012-SSPB 2.0x12" Smoothie Piggyback Reservoir 10.50 19.585 31.585
PR2014-SSPB 2.0x14" Smoothie Piggyback Reservoir 21.585 35.585
PR2016-SSPB 2.0x16" Smoothie Piggyback Reservoir 23.600 39.500
PR2506-SSNR 2.5x 6" Smoothie Emulsion 14.000 20.000
PR2508-SSNR 2.5x 8" Smoothie Emulsion 16.000 24.000
PR2510-SSNR 2.5x10" Smoothie Emulsion 18.375 28.375
PR2512-SSNR 2.5x12" Smoothie Emulsion 20.650 32.650
PR2514-SSNR 2.5x14" Smoothie Emulsion 23.250 37.250
PR2516-SSNR 2.5x16" Smoothie Emulsion 26.000 42.000
PR2518-SSNR 2.5x18" Smoothie Emulsion 28.000 46.000
PR2506-SS 2.5x 6" Smoothie Hose Reservoir 11.50 14.000 20.000
PR2508-SS 2.5x 8" Smoothie Hose Reservoir 12.00 16.000 24.000
PR2510-SS 2.5x10" Smoothie Hose Reservoir 13.50 18.375 28.375
PR2512-SS 2.5x12" Smoothie Hose Reservoir 15.00 20.650 32.650
PR2514-SS 2.5x14" Smoothie Hose Reservoir 16.50 23.250 37.250
PR2516-SS 2.5x16" Smoothie Hose Reservoir 18.00 26.000 42.000
PR2518-SS 2.5x18" Smoothie Hose Reservoir 19.50 28.000 46.000
PR2506-SSPB 2.5x 6" Smoothie Piggyback Reservoir 11.50 14.000 20.000
PR2508-SSPB 2.5x 8" Smoothie Piggyback Reservoir 12.00 16.000 24.000
PR2510-SSPB 2.5x10" Smoothie Piggyback Reservoir 13.00 18.375 28.375
PR2512-SSPB 2.5x12" Smoothie Piggyback Reservoir 14.50 20.650 32.650
PR2514-SSPB 2.5x14" Smoothie Piggyback Reservoir 16.00 23.250 37.250
PR2516-SSPB 2.5x16" Smoothie Piggyback Reservoir 17.50 26.000 42.000
PR2518-SSPB 2.5x18" Smoothie Piggyback Reservoir 20.00 28.000 46.000
PR3008-SS 3.0x 8" Smoothie Hose Reservoir 16.000 24.000
PR3010-SS 3.0x10" Smoothie Hose Reservoir 18.000 28.000
PR3012-SS 3.0x12" Smoothie Hose Reservoir 20.650 32.650
PR3014-SS 3.0x14" Smoothie Hose Reservoir 23.250 37.250
PR3016-SS 3.0x16" Smoothie Hose Reservoir 26.000 42.000
PR3018-SS 3.0x18" Smoothie Hose Reservoir 28.000 46.000
PR3008-SSP 3.0x 8" Smoothie Piggyback Reservoir 16.000 24.000
PR3010-SSP 3.0x10" Smoothie Piggyback Reservoir 18.000 28.000
PR3012-SSP 3.0x12" Smoothie Piggyback Reservoir 20.650 32.650
PR3014-SSP 3.0x14" Smoothie Piggyback Reservoir 23.250 37.250
PR3016-SSP 3.0x16" Smoothie Piggyback Reservoir 26.000 42.000
PR3018-SSP 3.0x18" Smoothie Piggyback Reservoir 28.000 46.000
[/size][/size][/size][/size]
[size=10pt][size=10pt][size=10pt][size=10pt]King Coil Over Shocks!
Call 706-207-4140!
King, Coil over shocks, provide the highest level of performance damping and suspension control for your vehicle. Their design allows for a space saving solution to your suspension mounting needs as they incorporate both the coil spring and shock absorber in one package. They are used as a primary suspension member to carry the weight of the vehicle and to maintain ride height while providing the adjustable valving and high quality ride characteristics King is famous for. All of our coil over shocks are custom made for your application. Our experienced designers work with you to determine the correct spring rate and valving you need to achieve ultimate performance. Our strict adherence to precision tolerances and quality materials insure you will own the finest coil over shocks available. Nothing rides like King.
2.0" / 2.5" Coil Over Piggy Back Remote Reservoir Emulsion
PR2006-CONR 2.0x 6" Coil Over Emulsion (w/o springs) 5.50 13.000 19.000
PR2006-CONRS 2.0x 6" Coil Over Emulsion (with springs) 13.000 19.000
PR2008-CONR 2.0x 8" Coil Over Emulsion (w/o springs) 6.50 15.000 23.000
PR2008-CONRS 2.0x 8" Coil Over Emulsion (with springs) 15.000 23.000
PR2010-CONR 2.0x10" Coil Over Emulsion (w/o springs) 7.50 17.050 27.050
PR2010-CONRS 2.0x10" Coil Over Emulsion (with springs) 17.050 27.050
PR2012-CONR 2.0x12" Coil Over Emulsion (w/o springs) 8.50 19.585 31.585
PR2012-CONRS 2.0x12" Coil Over Emulsion (with springs) 19.585 31.585
PR2014-CONR 2.0x14" Coil Over Emulsion (w/o springs) 9.50 21.585 35.585
PR2014-CONRS 2.0x14" Coil Over Emulsion (with springs) 21.585 35.585
PR2016-CONR 2.0x16" Coil Over Emulsion (w/o springs) 10.50 23.600 39.500
PR2016-CONRS 2.0x16" Coil Over Emulsion (with springs) 23.600 39.500
PR2006-COHR 2.0x 6" Coil Over Hose Reservoir (w/o springs) 8.50 13.000 19.000
PR2006-COHRS 2.0x 6" Coil Over Hose Reservoir (with springs) 13.000 19.000
PR2008-COHR 2.0x 8" Coil Over Hose Reservoir (w/o springs) 9.00 15.000 23.000
PR2008-COHRS 2.0x 8" Coil Over Hose Reservoir (with springs) 15.000 23.000
PR2010-COHR 2.0x10" Coil Over Hose Reservoir (w/o springs) 9.50 17.050 27.050
PR2010-COHRS 2.0x10" Coil Over Hose Reservoir (with springs) 17.050 27.050
PR2012-COHR 2.0x12" Coil Over Hose Reservoir (w/o springs) 10.50 19.585 31.585
PR2012-COHRS 2.0x12" Coil Over Hose Reservoir (with springs) 19.585 31.585
PR2014-COHR 2.0x14" Coil Over Hose Reservoir (w/o springs) 11.50 21.585 35.585
PR2014-COHRS 2.0x14" Coil Over Hose Reservoir (with springs) 21.585 35.585
PR2016-COHR 2.0x16" Coil Over Hose Reservoir (w/o springs) 12.50 23.600 39.500
PR2016-COHRS 2.0x16" Coil Over Hose Reservoir (with springs) 23.600 39.500
PR2006-COPB 2.0x 6" Coil Over Piggyback Reservoir (w/o springs) 7.00 13.000 19.000
PR2006-COPBS 2.0x 6" Coil Over Piggyback Reservoir (with springs) 13.000 19.000
PR2008-COPB 2.0x 8" Coil Over Piggyback Reservoir (w/o springs) 8.00 15.000 23.000
PR2008-COPBS 2.0x 8" Coil Over Piggyback Reservoir (with springs) 15.000 23.000
PR2010-COPB 2.0x10" Coil Over Piggyback Reservoir (w/o springs) 9.50 17.050 27.050
PR2010-COPBS 2.0x10" Coil Over Piggyback Reservoir (with springs) 17.050 27.050
PR2012-COPB 2.0x12" Coil Over Piggyback Reservoir (w/o springs) 10.50 19.585 31.585
PR2012-COPBS 2.0x12" Coil Over Piggyback Reservoir (with springs) 19.585 31.585
PR2014-COPB 2.0x14" Coil Over Piggyback Reservoir (w/o springs) 11.50 21.585 35.585
PR2014-COPBS 2.0x14" Coil Over Piggyback Reservoir (with springs) 21.585 35.585
PR2016-COPB 2.0x16" Coil Over Piggyback Reservoir (w/o springs) 12.50 23.600 39.500
PR2016-COPBS 2.0x16" Coil Over Piggyback Reservoir (with springs) 23.600 39.500
PR2506-CONR 2.5x 6" Coil Over Emulsion (w/o springs) 9.50 14.000 20.000
PR2506-CONRS 2.5x 6" Coil Over Emulsion (with springs) 14.000 20.000
PR2508-CONR 2.5x 8" Coil Over Emulsion (w/o springs) 10.00 16.000 24.000
PR2508-CONRS 2.5x 8" Coil Over Emulsion (with springs) 16.000 24.000
PR2510-CONR 2.5x10" Coil Over Emulsion (w/o springs) 11.00 18.375 28.375
PR2510-CONRS 2.5x10" Coil Over Emulsion (with springs) 18.375 28.375
PR2512-CONR 2.5x12" Coil Over Emulsion (w/o springs) 12.00 20.650 32.650
PR2512-CONRS 2.5x12" Coil Over Emulsion (with springs) 20.650 32.650
PR2514-CONR 2.5x14" Coil Over Emulsion (w/o springs) 13.00 23.250 37.250
PR2514-CONRS 2.5x14" Coil Over Emulsion (with springs) 23.250 37.250
PR2516-CONR 2.5x16" Coil Over Emulsion (w/o springs) 14.00 26.000 42.000
PR2516-CONRS 2.5x16" Coil Over Emulsion (with springs) 26.000 42.000
PR2518-CONR 2.5x18" Coil Over Emulsion (w/o springs) 15.00 28.000 46.000
PR2518-CONRS 2.5x18" Coil Over Emulsion (with springs) 28.000 46.000
PR2506-COHR 2.5x 6" Coil Over Hose Reservoir (w/o springs) 12.50 14.000 20.000
PR2506-COHRS 2.5x 6" Coil Over Hose Reservoir (with springs) 14.000 20.000
PR2508-COHR 2.5x 8" Coil Over Hose Reservoir (w/o springs) 13.00 16.000 24.000
PR2508-COHRS 2.5x 8" Coil Over Hose Reservoir (with springs) 16.000 24.000
PR2510-COHR 2.5x10" Coil Over Hose Reservoir (w/o springs) 14.00 18.375 28.375
PR2510-COHRS 2.5x10" Coil Over Hose Reservoir (with springs) 18.375 28.375
PR2512-COHR 2.5x12" Coil Over Hose Reservoir (w/o springs) 16.00 20.650 32.650
PR2512-COHRS 2.5x12" Coil Over Hose Reservoir (with springs) 20.650 32.650
PR2514-COHR 2.5x14" Coil Over Hose Reservoir (w/o springs) 17.50 23.250 37.250
PR2514-COHRS 2.5x14" Coil Over Hose Reservoir (with springs) 23.250 37.250
PR2516-COHR 2.5x16" Coil Over Hose Reservoir (w/o springs) 18.50 26.000 42.000
PR2516-COHRS 2.5x16" Coil Over Hose Reservoir (with springs) 26.000 42.000
PR2518-COHR 2.5x18" Coil Over Hose Reservoir (w/o springs) 19.50 28.000 46.000
PR2518-COHRS 2.5x18" Coil Over Hose Reservoir (with springs) 28.000 46.000
PR2506-COPB 2.5x 6" Coil Over Piggyback Reservoir (w/o springs) 12.50 14.000 20.000
PR2506-COPBS 2.5x 6" Coil Over Piggyback Reservoir (with springs) 14.000 20.000
PR2508-COPB 2.5x 8" Coil Over Piggyback Reservoir (w/o springs) 13.00 16.000 24.000
PR2508-COPBS 2.5x 8" Coil Over Piggyback Reservoir (with springs) 16.000 24.000
PR2510-COPB 2.5x10" Coil Over Piggyback Reservoir (w/o springs) 14.00 18.375 28.375
PR2510-COPBS 2.5x10" Coil Over Piggyback Reservoir (with springs) 18.375 28.375
PR2512-COPB 2.5x12" Coil Over Piggyback Reservoir (w/o springs) 16.00 20.650 32.650
PR2512-COPBS 2.5x12" Coil Over Piggyback Reservoir (with springs) 20.650 32.650
PR2514-COPB 2.5x14" Coil Over Piggyback Reservoir (w/o springs) 17.00 23.250 37.250
PR2514-COPBS 2.5x14" Coil Over Piggyback Reservoir (with springs) 23.250 37.250
PR2516-COPB 2.5x16" Coil Over Piggyback Reservoir (w/o springs) 18.00 26.000 42.000
PR2516-COPBS 2.5x16" Coil Over Piggyback Reservoir (with springs) 26.000 42.000
PR2518-COPB 2.5x18" Coil Over Piggyback Reservoir (w/o springs) 20.00 28.000 46.000
PR2518-COPBS 2.5x18" Coil Over Piggyback Reservoir (with springs) 28.000 46.000
PR3008-COHR 3.0x 8" Coil Over Hose Reservoir (w/o springs) 16.000 24.000
PR3008-COHRS 3.0x 8" Coil Over Hose Reservoir (with springs) 16.000 24.000
PR3010-COHR 3.0x10" Coil Over Hose Reservoir (w/o springs) 18.375 28.375
PR3010-COHRS 3.0x10" Coil Over Hose Reservoir (with springs) 18.375 28.375
PR3012-COHR 3.0x12" Coil Over Hose Reservoir (w/o springs) 20.650 32.650
PR3012-COHRS 3.0x12" Coil Over Hose Reservoir (with springs) 20.650 32.650
PR3014-COHR 3.0x14" Coil Over Hose Reservoir (w/o springs) 23.250 37.250
PR3014-COHRS 3.0x14" Coil Over Hose Reservoir (with springs) 23.250 37.250
PR3016-COHR 3.0x16" Coil Over Hose Reservoir (w/o springs) 26.000 42.000
PR3016-COHRS 3.0x16" Coil Over Hose Reservoir (with springs) 26.000 42.000
PR3018-COHR 3.0x18" Coil Over Hose Reservoir (w/o springs) 28.000 46.000
PR3018-COHRS 3.0x18" Coil Over Hose Reservoir (with springs) 28.000 46.000
PR2006-CCNR 2.0x 6" Coil Carrier Emulsion (w/o springs) 5.50 13.000 19.000
PR2006-CCNRS 2.0x 6" Coil Carrier Emulsion (with springs) 13.000 19.000
PR2008-CCNR 2.0x 8" Coil Carrier Emulsion (w/o springs) 6.50 15.000 23.000
PR2008-CCNRS 2.0x 8" Coil Carrier Emulsion (with springs) 15.000 23.000
PR2010-CCNR 2.0x10" Coil Carrier Emulsion (w/o springs) 7.50 17.050 27.050
PR2010-CCNRS 2.0x10" Coil Carrier Emulsion (with springs) 17.050 27.050
PR2012-CCNR 2.0x12" Coil Carrier Emulsion (w/o springs) 8.50 19.585 31.585
PR2012-CCNRS 2.0x12" Coil Carrier Emulsion (with springs) 19.585 31.585
PR2014-CCNR 2.0x14" Coil Carrier Emulsion (w/o springs) 9.50 21.585 35.585
PR2014-CCNRS 2.0x14" Coil Carrier Emulsion (with springs) 21.585 35.585
PR2016-CCNR 2.0x16" Coil Carrier Emulsion (w/o springs) 9.50 23.600 39.500
PR2016-CCNRS 2.0x16" Coil Carrier Emulsion (with springs) 23.600 39.500
PR2506-CCNR 2.5x 6" Coil Carrier Emulsion (w/o springs) 14.000 20.000
PR2506-CCNRS 2.5x 6" Coil Carrier Emulsion (with springs) 14.000 20.000
PR2508-CCNR 2.5x 8" Coil Carrier Emulsion (w/o springs) 10.00 16.000 24.000
PR2508-CCNRS 2.5x 8" Coil Carrier Emulsion (with springs) 16.000 24.000
PR2510-CCNR 2.5x10" Coil Carrier Emulsion (w/o springs) 11.00 18.380 28.380
PR2510-CCNRS 2.5x10" Coil Carrier Emulsion (with springs) 18.380 28.380
PR2512-CCNR 2.5x12" Coil Carrier Emulsion (w/o springs) 12.00 20.630 32.630
PR2512-CCNRS 2.5x12" Coil Carrier Emulsion (with springs) 20.630 32.630
PR2514-CCNR 2.5x14" Coil Carrier Emulsion (w/o springs) 13.00 23.250 37.250
PR2514-CCNRS 2.5x14" Coil Carrier Emulsion (with springs) 23.250 37.250
PR2516-CCNR 2.5x16" Coil Carrier Emulsion (w/o springs) 14.00 26.000 42.000
PR2516-CCNRS 2.5x16" Coil Carrier Emulsion (with springs) 26.000 42.000
PR2518-CCNR 2.5x18" Coil Carrier Emulsion (w/o springs) 15.00 28.000 46.000
PR2518-CCNRS 2.5x18" Coil Carrier Emulsion (with springs) 28.000 46.000
[size=10pt][size=10pt][size=10pt][size=10pt][size=10pt]King Bypass Shocks
Call 706-207-4140!
King's bypass shock technology represents a culmination of refinement dating back to the original design concept over a decade ago. No matter what the demands placed on your suspension, King can provide configuration specific bypass designs to assure complete control of high speed and low speed oscillations with our position sensitive damping. Tube quantity and location are based on our time tested standard locations or your entirely unique custom application.
Our bypass valve design and superior tube flow capacity provides accurate flow control over the whole range of adjustment. Our precise manufacturing processes and strict adherence to quality standards makes this possible. Our bypass valve springs are made out of the same material we use for our valve shims to reduce the possibility of heat induced fade compromising your settings. Shock tubes are honed after plating to assure a tight piston seal and all bypass ports are cnc drilled and hand deburred then polished. This commitment to quality and attention to detail creates enhanced flow control and unparalleled levels of precision adjustment. When you combine this level of functionality with our depth of knowledge setting up your valving and bypass settings you will enjoy enhanced car control, reduced driver fatigue and sustained peak performance. Once you experience King shocks you will know there really is a difference. Nothing rides like a King.
2.0 / 2.5 / 3.0 Bypass Remote Reservoir and Piggy Back Reservoir
PR2006-BP2H 2.0x 6" 2 Tube Bypass Shock Hose Reservoir 10.00 13.000 19.000
PR2008-BP2H 2.0x 8" 2 Tube Bypass Shock Hose Reservoir 10.50 15.000 23.000
PR2010-BP2H 2.0x10" 2 Tube Bypass Shock Hose Reservoir 11.50 17.050 27.050
PR2012-BP2H 2.0x12" 2 Tube Bypass Shock Hose Reservoir 12.50 19.585 31.585
PR2014-BP2H 2.0x14" 2 Tube Bypass Shock Hose Reservoir 13.00 21.585 35.585
PR2016-BP2H 2.0x16" 2 Tube Bypass Shock Hose Reservoir 14.50 23.600 39.500
PR2006-BP2P 2.0x 6" 2 Tube Bypass Shock Piggyback Reservoir 8.00 13.000 19.000
PR2008-BP2P 2.0x 8" 2 Tube Bypass Shock Piggyback Reservoir 8.50 15.000 23.000
PR2010-BP2P 2.0x10" 2 Tube Bypass Shock Piggyback Reservoir 10.00 17.050 27.050
PR2012-BP2P 2.0x12" 2 Tube Bypass Shock Piggyback Reservoir 11.50 19.585 31.585
PR2014-BP2P 2.0x14" 2 Tube Bypass Shock Piggyback Reservoir 13.00 21.585 35.585
PR2016-BP2P 2.0x16" 2 Tube Bypass Shock Piggyback Reservoir 14.00 23.600 39.500
PR2006-BP3H 2.0x 6" 3 Tube Bypass Shock Hose Reservoir 10.00 13.000 19.000
PR2008-BP3H 2.0x 8" 3 Tube Bypass Shock Hose Reservoir 10.50 15.000 23.000
PR2010-BP3H 2.0x10" 3 Tube Bypass Shock Hose Reservoir 11.50 17.050 27.050
PR2012-BP3H 2.0x12" 3 Tube Bypass Shock Hose Reservoir 12.50 19.585 31.585
PR2014-BP3H 2.0x14" 3 Tube Bypass Shock Hose Reservoir 13.00 21.585 35.585
PR2016-BP3H 2.0x16" 3 Tube Bypass Shock Hose Reservoir 14.50 23.600 39.500
PR2006-BP3P 2.0x 6" 3 Tube Bypass Shock Piggyback Reservoir 8.00 13.000 19.000
PR2008-BP3P 2.0x 8" 3 Tube Bypass Shock Piggyback Reservoir 8.50 15.000 23.000
PR2010-BP3P 2.0x10" 3 Tube Bypass Shock Piggyback Reservoir 10.00 17.050 27.050
PR2012-BP3P 2.0x12" 3 Tube Bypass Shock Piggyback Reservoir 11.50 19.585 31.585
PR2014-BP3P 2.0x14" 3 Tube Bypass Shock Piggyback Reservoir 13.00 21.585 35.585
PR2016-BP3P 2.0x16" 3 Tube Bypass Shock Piggyback Reservoir 14.00 23.600 39.500
PR2506-BP2H 2.5x 6" 2 Tube Bypass Shock Hose Reservoir 12.00 14.000 20.000
PR2508-BP2H 2.5x 8" 2 Tube Bypass Shock Hose Reservoir 13.00 16.000 24.000
PR2510-BP2H 2.5x10" 2 Tube Bypass Shock Hose Reservoir 14.50 18.375 28.375
PR2512-BP2H 2.5x12" 2 Tube Bypass Shock Hose Reservoir 15.50 20.650 32.650
PR2514-BP2H 2.5x14" 2 Tube Bypass Shock Hose Reservoir 18.00 23.250 37.250
PR2516-BP2H 2.5x16" 2 Tube Bypass Shock Hose Reservoir 20.50 26.000 42.000
PR2518-BP2H 2.5x18" 2 Tube Bypass Shock Hose Reservoir 22.00 28.000 46.000
PR2506-BP2P 2.5x 6" 2 Tube Bypass Shock Piggyback Reservoir 11.50 14.000 20.000
PR2508-BP2P 2.5x 8" 2 Tube Bypass Shock Piggyback Reservoir 12.00 16.000 24.000
PR2510-BP2P 2.5x10" 2 Tube Bypass Shock Piggyback Reservoir 13.00 18.380 28.380
PR2512-BP2P 2.5x12" 2 Tube Bypass Shock Piggyback Reservoir 15.50 20.630 32.630
PR2514-BP2P 2.5x14" 2 Tube Bypass Shock Piggyback Reservoir 17.00 23.250 37.250
PR2516-BP2P 2.5x16" 2 Tube Bypass Shock Piggyback Reservoir 19.50 26.000 42.000
PR2518-BP2P 2.5x18" 2 Tube Bypass Shock Piggyback Reservoir 21.50 28.000 46.000
PR2506-BP3H 2.5x 6" 3 Tube Bypass Shock Hose Reservoir 13.50 14.000 20.000
PR2508-BP3H 2.5x 8" 3 Tube Bypass Shock Hose Reservoir 14.00 16.000 24.000
PR2510-BP3H 2.5x10" 3 Tube Bypass Shock Hose Reservoir 15.00 18.375 28.375
PR2512-BP3H 2.5x12" 3 Tube Bypass Shock Hose Reservoir 17.50 20.650 32.650
PR2514-BP3H 2.5x14" 3 Tube Bypass Shock Hose Reservoir 19.50 23.250 37.250
PR2516-BP3H 2.5x16" 3 Tube Bypass Shock Hose Reservoir 23.00 26.000 42.000
PR2518-BP3H 2.5x18" 3 Tube Bypass Shock Hose Reservoir 26.50 28.000 46.000
PR2506-BP3P 2.5x 6" 3 Tube Bypass Shock Piggyback Reservoir 13.00 14.000 20.000
PR2508-BP3P 2.5x 8" 3 Tube Bypass Shock Piggyback Reservoir 13.50 16.000 24.000
PR2510-BP3P 2.5x10" 3 Tube Bypass Shock Piggyback Reservoir 14.00 18.375 28.375
PR2512-BP3P 2.5x12" 3 Tube Bypass Shock Piggyback Reservoir 18.00 20.650 32.650
PR2514-BP3P 2.5x14" 3 Tube Bypass Shock Piggyback Reservoir 20.50 23.250 37.250
PR2516-BP3P 2.5x16" 3 Tube Bypass Shock Piggyback Reservoir 23.00 26.000 42.00
PR2518-BP3P 2.5x18" 3 Tube Bypass Shock Piggyback Reservoir 25.50 28.000 46.00
PR3008-BP2H 3.0x 8" 2 Tube Bypass Shock Hose Reservoir 23.00 16.000 24.000
PR3010-BP2H 3.0x10" 2 Tube Bypass Shock Hose Reservoir 23.50 18.375 28.375
PR3012-BP2H 3.0x12" 2 Tube Bypass Shock Hose Reservoir 25.00 20.650 32.650
PR3014-BP2H 3.0x14" 2 Tube Bypass Shock Hose Reservoir 27.50 23.250 37.250
PR3016-BP2H 3.0x16" 2 Tube Bypass Shock Hose Reservoir 29.00 26.000 42.000
PR3018-BP2H 3.0x18" 2 Tube Bypass Shock Hose Reservoir 31.50 28.000 46.000
PR3008-BP2P 3.0x 8" 2 Tube Bypass Shock Piggyback Reservoir 20.00 16.000 24.000
PR3010-BP2P 3.0x10" 2 Tube Bypass Shock Piggyback Reservoir 21.00 18.375 28.375
PR3012-BP2P 3.0x12" 2 Tube Bypass Shock Piggyback Reservoir 22.00 20.650 32.650
PR3014-BP2P 3.0x14" 2 Tube Bypass Shock Piggyback Reservoir 24.50 23.250 37.250
PR3016-BP2P 3.0x16" 2 Tube Bypass Shock Piggyback Reservoir 28.50 26.000 42.000
PR3018-BP2P 3.0x18" 2 Tube Bypass Shock Piggyback Reservoir 31.50 28.000 46.000
PR3008-BP3H 3.0x 8" 3 Tube Bypass Shock Hose Reservoir 23.00 16.000 24.000
PR3010-BP3H 3.0x10" 3 Tube Bypass Shock Hose Reservoir 23.50 18.375 28.375
PR3012-BP3H 3.0x12" 3 Tube Bypass Shock Hose Reservoir 25.00 20.650 32.650
PR3014-BP3H 3.0x14" 3 Tube Bypass Shock Hose Reservoir 27.50 23.250 37.250
PR3016-BP3H 3.0x16" 3 Tube Bypass Shock Hose Reservoir 29.00 26.000 42.000
PR3018-BP3H 3.0x18" 3 Tube Bypass Shock Hose Reservoir 31.50 28.000 46.000
PR3008-BP3P 3.0x 8" 3 Tube Bypass Shock Piggyback Reservoir 20.00 16.000 24.000
PR3010-BP3P 3.0x10" 3 Tube Bypass Shock Piggyback Reservoir 21.00 18.375 28.375
PR3012-BP3P 3.0x12" 3 Tube Bypass Shock Piggyback Reservoir 22.00 20.650 32.650
PR3014-BP3P 3.0x14" 3 Tube Bypass Shock Piggyback Reservoir 24.50 23.250 37.250
PR3016-BP3P 3.0x16" 3 Tube Bypass Shock Piggyback Reservoir 28.50 26.000 42.000
PR3018-BP3P 3.0x18" 3 Tube Bypass Shock Piggyback Reservoir 31.50 28.000 46.000
[/size][/size][/size][/size][/size]
[size=10pt][size=10pt][size=10pt][size=10pt][size=10pt][size=10pt]Call us up if you don't see what you need!
Thanks for the orders!!!
Bobby
Sales Manager
CCOR
706-207-4140
[/size][/size][/size][/size][/size][/size]
We have two events that we are apart of every Month.
The 1st is with Stocker's to Lockers
It is held at Beef O'Brady's in Jefferson, GA on the 1st Thursday of the month starting around 6:00pm Which would be 2/7/13
The 2nd is our official event.
CCOR 4WD Cruise-IN
810 Hawthorne Ave
Athens, GA 30606
Our event is the 2nd Thursday of the month but this one will be on Friday 2/15/13 due to Valentine's Day. Our even starts at around 6:00 too.
Both events are a lot of fun, eat, drink, Jeep, & be merry. Family oriented but they both do have a bar if you wanna have a drink.
If you want more information then call me at 706-207-4140.
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
