machinewave
- Joined
- Feb 19, 2008
- Messages
- 66
- Reaction score
- 0
KOH/Ultra4/TTC Buggy For Sale***
I had this complete buggy for sale last summer! It did not sell so I have since sold several parts off of it, including the front axle, the tires and wheels, plus a few misc parts. I have the engine and the rear axle for sale separately, but would now like to sell the chassis and all accompanying parts to someone intersted in racing, etc....
I'm asking $35K for the chassis, minus the axles, tires, wheels, and engine...everything else is still together. Please look at the list of parts and let me know if interested...if it doesn't sell I will be completely parting it out over the next few months...so let me know if interested in any parts as well...
This vehicle was built with no comprimises in parts or detail. It has been redesigned a few times over its life to accomodate the Top Truck Challenge in 2008, and as of late, the Ultra 4 Race Series (2010-2011) and King of the Hammers 2012...
We can outfit this vehicle to race or trail ride as well if interested. The wheelbase, axles, tires and wheels, and engine combo could be varied for any type of use!
You can contact me via Pirate PM: machinewave, email: [email protected] or phone: 812-623-3473
Builder: MachineWave/SunFire Off-Road
Vehicle: "The Weapon"
Ultra 4: #4492
Full Tube Chassis - 2" primary, 1 3/4" and 1 1/2" secondary DOM Tubing
Aluminum Body Panels w/ Dzus Fasteners
Custom Painted Chassis & Panels
Engine Compartment:
- Amsoil ByPass Oil Filter System
- Howe Small Heat Sink Fuel Cooler
- Reinforced Motor Mounts and Mid Plate
- Aeromotive Dual Fuel Pumps/Pre Filters/Post Filters
- Aeromotive & Earls AN Hoses & Fittings Throughout Fuel/Oil System
Coan TH400 Transmission
- 300M Internals
- Coan 2.98 to 1 First Gear w/ Maximum Duty Straight Cut Planetary Set
- Coan Ultimate Super Drum w/ Super Sprag
- Art Carr Gated Shifter
- Art Carr Reverse Manual Valve Body w/ Engine Brake
- Coan HD Torque Converter
- Meziere HD Billet Flexplate
- B&M HD Tranny Cooler w/ Fan x2
- Howe Large Heat Sink Coolers x2
- Custom MidPlate
Advance Adapters Atlas 2 Speed Transfer Case
- 2 to 1 Low Gear
- New HD Atlas Race Case/Gears
- 32 Spline Outputs
- Torque Lock Gears
- 300M Output Shaft
- Cable Shift
- External Pump and Coolers
High Angle Driveline 1410 CV Driveshafts
- Front & Rear Durability CVs
- Trophy Truck Rear Chromoly Slip
- 42 Degree
- 1/4" Wall Tubing
King 2.5" x 18" Coilovers w/ Remote Reservoirs
King 2.5" x 18" Triple ByPass Shocks
King 2.5" Air Bumps
- Front and Rear
- Set Up for triangulated 4 Link front and rear
- Anti Rock Sway Bars #Front & Rear#
- 1 1/4" Aurora Chromoly Rod Ends Throughout
- Solid Wall 7075 AluminummLinks on Front
- Stainless Steel High Misalignment Spacers
High Performance Full Hydro Steering System - Front & Rear Steer
- Howe Performance - Quick Disconnect Steering Wheel
- Stazworks Self-Center Electronic Rear Steer w/ Override
- Howe High Pressure ByPass on Front Steering
- Aeroquip High Pressure Hoses and Fittings Throughout Steering System
High Performance Brake System
- Goodridge -3AN Braided Stainless Steel Brake Lines - Complete System
Ron Davis Custom Aluminum Radiator - 28" x 28" Rear Mounted w/ Four #4# - 13" SPAL Electric Fans
Fuel Safe Custom 3-Piece 30 Gallon Fuel Tank
- Fuel Safe Dry Break #Quick Fill#
- Fuel Safe 11 Gallon Dump Cans w/ Dry Breaks #x6#
T-Max 12K Integrated Outback Series Winches #Front & Rear#
Baja Designs/SolTek Lighting
- Ten #10# SolTek 6" HID Pre-Runner Race Lights
- Two #2# SolTek 8" HID Desert Race Lights
Lazerstar Billet LED Running Lights/Tail-Lights/Brake Lights
- HID Back-Up Lights
- LED Red/Blue/Amber Rear Lights
Beard Ultra TR-1 Racing Seats
TeamTech Race Harnesses
- Tucker Head and Neck Restraint System
PCI Race Radios Communications
- Lowrance GPS Baja 480C
- HJC Racing Helmets #air and wired# x2
- Comm10 Intercom
- Bluetooth Wireless - between driver and co-driver/pits
- Go Pro HD - wired through intercom
Dual Kinetic Batteries
Full Front and Rear Skid Plates
Beard Custom Window Nets w/ Quick Release
Baja SS Break-A-Way Pillar Mirrors
Autometer Gauges & 1" Warning Lights
All Waterproof and Loomed Wiring
Vented Catch Cans for Diffs/Tranny/Tcase
Stainless Steel TT Gas Pedal
Lokar Throttle Cable
4UCam OnBoard Camera System w/ 3 Cameras for BackUp/Front/Lower Diff
Powertank - 15 lb Polished Tank
Powertank JetPak II ARB CO2 Toggle System
SafeCraft On-Board Fire Extinguisher
H3R 2.5lb Fire Extinguishers #4#
All Grade 8 or Better Hardware
- L9 Hardware for Links and Axle Components
Many Spares
Ultra 4: #4492
Engine Compartment:
- 300M Internals
- Custom MidPlate
- 2 to 1 Low Gear
- 32 Spline Outputs
- Torque Lock Gears
- 300M Output Shaft
- Cable Shift
- 42 Degree
- 1/4" Wall Tubing
King 2.5" Air Bumps
- Front and Rear
- Comm10 Intercom
Many Spares
