We're excited to finally get this added to our product line.
First out are the Dana 60's
Looking for some heavy duty protection for your exspensive axle internals?
These KORE Dana 60 Differential Covers are the answer to protect your money invested in your axle gears & locker!
Features:
- Oversized 1-1/4" Easy Access anodized fill plug with O-Ring
- 3/8" Thick CNC cut Diff Ring keeps the 'lip' from getting peeled back when traveling over rocks
- The main body is CNC cut from one piece of 3/8" Thick Hi Strength Steel & then formed 8 ways on a press brake to provide the strongest Diff Cover possible
- Fully Fixture welded inside & out
- After welding, the gasket surface is machined truly flat to provide a proper sealing surface
- Bolt holes are machined on the top side of the flange to allow a flat surface for proper torquing of the bolts
Introductory offer on these directly on our site...Check it out HERE
Features:
