handloader90
Located in Clarksville, TN (45 mins. North of Nashville)
Selling/Trading my CUCV SRW 1 Ton axles.
SRW Chevy Dana 60 and SRW 14 Bolt Full Floater matching set pulled from the same CUCV.
Both axles have 4.56 ring and pinion.
Dana 60 is open. 14 Bolt has a Detroit Locker.
Dana 60 is complete minus having the factory shock mounts removed.
14 Bolt is complete minus having factory spring perches, shock mounts and all drum brake items removed.
New Studs/U-Bolts for the Dana 60, new U-Bolts for the 14 Bolt. Both kits purchased from Offroad Design. Studs/U-Bolts are finished with Zinc.
New RuffStuff spring perches for the 14 Bolt.
New RuffStuff monster shock mounts for the 14 Bolt.
New DIY4X fully boxed spring plates for the Dana 60.
New DIY4X full boxed spring plates for the 14 Bolt.
New DIY4X disc brake brackets for the 14 Bolt.
New DIY4X HD diff cover for the 14 Bolt.
New DIY4X pinion guard for the 14 Bolt.
New DIY4X shock mounts for the Dana 60 (These are the style which get welded to part of the inner C and part of the axle tube).
Asking $420.00 for all of the new axle parts listed above.
These axles are 100% in good working condition. The 14 Bolt needs paint and the disc brake swap completed.
Asking $1,400 for both axles by themselves or $1,780 for axles plus parts listed above.
Trade for + boot: A set of 3/4 Ton Chevy Axles. Specifically, a stock (not built or modified) matching set of SRW Dana 44 and SRW 14 Bolt Full Floater with matching 3.73 or 4.10 ring and pinion (preferably 4.10).
If you have a set of axles matching that description let me know exactly what you have and we can hash out the price from there.
