I have a LQ9 out of a 2004 Cadillac Escalade wired and ready to go. The wiring harness is already setup with relays for fans, fuel pump, and one other acc. The harness had a built in fuse panel and only take hooking up a hot wire and a ground to start. I have a motor stand if you would like to see it start before you buy that’s fine too. The motor is setup for drive by cable already so no need to convert or try to make the drive by wire setup work.
I have A LS1 intake and oil pan if someone wanted or needed them for the build. The buyer of motor has first chose thought.
Oil pan $250
Intake $300….. Yes injectors and fuel rail.
Motor is located in NW Arkansas and I will ship on your dime no charge on my side to package it.
Call or text me for pic’s and info. 479-236-0625
Oil pan $250
