Sold/Expired MJ Truggy Project (parting)
RoyalXJ
Member
I lost interest in this so I'm abandoneding my project. Located in southern NJ.
-88 Comanche Chassis (has ***le), backhalved, front is dove tailed, interior and engine cage. All tube is 1.75" DOM
-3 linked in front and 4 linked in the rear. Links are 2" .250 square tube w/ Currie JJs, 14" Sway Away air shocks in the front, setup for 16" shocks in the rear
-Chevy Vortec 4.3 w/ reworked harness and computer.
-Wilwood brake pedal and master cylinder
-Novak TH350 to NP207, NP231, NP242, NP249, NP242 & NP241OR adapter.
-Jeep Dana 300 transfer case
-Trans cooler w/ e fan and cooler lines.
-Aluminum radiator w/ Taurus e fan & trans cooler w/ line and e fan.
- HP60, new kingpins narrowed, trussed, ballistic fab dif cover, custom chromoly 35 spline shafts,5.13 gears and master install kit. aluminum performance brake calipers, converted 5x5.5, set up for 3 link. needs a carrier
- semi float D60, trussed, narrowed, ballistic fab dif cover, set up for 4 link, 5.13 gears, full spool, custom chromoly 35 spline shafts, weld on caliper brackets.
- custom Tom Woods driveshafts
-(4)Super Swamper TSLs 39.5x15x15 on d windows.
Needs finishing. Comes with some random parts and a set of 33" rollers as well. Bottom dollar is $4000.
