Sold/Expired Moving Sale
paradisepwoffrd
61
Hickory, NC
In the middle of moving, and figured I should try to have less to store.
I will update the thread with new items as I come across them. If it is listed here, it is still available. Feel free to make an offer. Will give deals on multiple items.
94 Tracker/Sidekick parts: All FI stuff minus harness & pump; A/C system parts; fuel tank; other small parts, lights, etc. $100
2" lift spacers for Jeep ZJ/TJ/XJ. I have 2 pr. $50/pr
Procomp shocks & steering stabilizer, used but still have resistance. 32451, 32450. $50 for all
NP249 transfer case from Jeep ZJ. $50
NP231 main shaft & trail cone for Jeep. $20
JKS-9602 shock conversion. never installed. $50
Jeep YJ half door windows. Dirty but might can clean up. 2 windows and a frame. $40
Jeep ZJ V8 radiator. Alum with plastic tanks. Used but in good shape. $40
Chevy 4spd Saginaw side shift w/ np208 & driveshafts. $200
Yamaha Rhino ('07, 660) Plastics. Hood, cowl, rear fenders. Have been rhino lined. Small crack in RR fender corner. $350
Speed Demon 4bbl carb. 1208010V. 650cfm, mechanical secondaries, no choke. Only ran for a few weeks. $250
Dodge/Scout Copper Radiator. Was in Scout II with 318 v8. $50
Set of 9" gears. 4.88. Ran for a few races in an offroad car. $100
EB headlight bucket & surrounds. Can include the H4 lights too. $40 without, $75 with lights
EB wiper motor & linkage $50
EB hood bracket $5
351c push-in dipstick. speedway 720-9223. $5
Factory Rockwell boot gaurds $20
Big Truck Chrome Air Horns with button and solenoid. $75
Tahoe air filter Purolator A45314. NIB $10
Marine radio enclosure. Good condition. $20
Toyota 22R random engine parts. timing gears, freeze plugs, valve seals, etc. $40
~'79 Dodge 318 V8... comes with alum intake, exhaust manifolds, flywheel and flexplate, etc... $250
Everything is located in Newton, nc.
Open to trades or offers.
Demon Carb
index.php
index.php
Dodge Radiator
index.php
Rhino Plastics
index.php
index.php
index.php
index.php
index.php
not planning to move far, just need a bigger house/shop.
Lately I havent been getting out of the state to ride. Depending on what you are interested in, I might can ship or meet/get it partially to you.
Re: Re: Moving Sale
Needs engine, trans, tcase, skid, rad. Hook wiring back up.
Then whatever lift or suspension/axles you wanted under it
Don't guess those axle shafts would fit a Ford HP44 big hub 8 lug axle out of a 78 3/4 ton truck?? Mine are 19 spline outer and 30 inner
Re: Re: Moving Sale
The f150 hp44 have shorter long side & longer short side then the f250 hp44. Would need another long side shaft. Sorry is close enough to work. Outers will work.
