NARROWED DANA 60HP BOLT IN FOR YJ-CJ AND 14 BOLT COMBO
bronco2bcn
Member
One Dana 60hp axle out of 88 f350. Rear is a 14 bolt cab and chassis rear.front is narrowed to 64 inches rear is 63.5 wide.these are basically bolt spring over axles for a yj or cj. Front axle specs Narrowed to 64 inches 4.10 welded center Resplined stock inner shaft 35 spline 4340 stub shafts Mile marker lockouts High steer arms Steering linkage Hydro assist ram Diff cover protector 14 bolt 4.10 open diff Can and chassis width Ruffstuf disc brake conversion Asking 2200 obo text or call Travis at 540-810-7736 located near Harrisonburg Va
One Dana 60hp lh drop axle out of 88 f350. Rear is a 14 bolt cab and chassis rear.front is narrowed to 64 inches rear is 63.5 wide.these are basically bolt spring over axles for a yj or cj. Front axle specs Narrowed to 64 inches 4.10 welded center Resplined stock inner shaft 35 spline 4340 stub shafts Mile marker lockouts High steer arms Steering linkage Hydro assist ram Diff cover protector 14 bolt 4.10 open diff Can and chassis width Ruffstuf disc brake conversion Asking 2200 obo text or call Travis at 540-810-7736 located near Harrisonburg Va
Can setup with locker and gears of your choice for additional dollars.
Any interest in a all aluminum ford 2.5 plug and play 2013 model dual over head multi fuel engine
