Sold/Expired New Product Aluminum Fire Extinguisher Mount
Scuba Jeepster
Benton, AR
Just got in my first batch of Fire Extinguisher Mounts. You won't find these anywhere else, designed for Off-Road Solutions. Aluminum/Stainless Best Part of all Made in the USA
Fire Extinguisher mounts with hose clamps or the ORS Ring Mounts base unit can either mount with clamps, ORS Ring Mounts or surface mounted using the pre-drilled counter sunk holes. The design allows the unit to mount on a flat surface or round roll cage. Pin lanyard will attach on the base hose clamp or the bolt that would surface mount. Pull the pin, unit swivels apart for fire extinguisher removal.
?7" long 1" wide 1 1/4" from mounting surface to mounting surface.
$70 shipped
Does not include mounting hardware or extinguisher
Hey Guys, been really busy with life so haven't been around much. I just finished up the design on my cage clamp for the fire extinguisher mount.
I just finished these up, and have them available, I'm about to order up a batch and wanted to see if anyone here would be interested in a set. They will probably list right at $55, for the clamp if you already have a FE Mount. For the extinguisher mount and the tube clamps will be $110
I"ll have the same set up for the extinguisher itself in the not to distant future.
Aluminum Cage clamp fits 1 3/4 tube. These are designed to attach to the pre-existing Fire Extinguisher mount.
I don't have them on my website yet.
Here's an installed photo of what they look like, had one set in Moab for some testing and such.
Re: New Product Aluminum Fire Extinguisher Mount
Rock Bouncer Abused !
Adam had two of my quick release mounts at the SRRS this past weekend he actually ha one mounted on his axle truss for easy access if needed when in his lid
