fatguy7814
Almost Finished!!!
Brand New, Rear Steer, ORIs, 6.0/400/Atlas & 42” Stickys
Texas Buggy built with no corners cut!!!! http://www.texas4x4.org/projects-forum-55/new-buggy-build-40501 Needs Wired and Pumbed. I have an Awesome Bid from EOR to finish it out!!!!
Chevy 6.0 with 58k
Turbo 400 with all Billet Internals and 2500 Stall
Atlas II 3.8
Triangulated 4 Link Front and Rear with Johny Joints
Stazworks Rear Steer electric return to center with LED Indicators
Narrowed and Mohawked Steering Rockwells
8 Lug Conversions
Overson Chromalloy 16 Spline Shafts in Rear
Custom Hummer Bead Locks
42’’ Irok Stickys
& tones of new in the box parts Almost everything needed to finish it.
1.Power Steering Cooler with Fan.
2.Trans Cooler
3. 2 Jegs 16'' Fans
4. Holley Fuel Regulator
5. 30' of Hydrolic hose
6.20' of -12 Push lock hose.
7.Howe Dual Res Double Peddle
8. Steering and Valve mounted.
9. Belly Pan.
10. 2 Power steering Pumps will be mounted.
11. 2 Remote reservoirs and mounts.
12. Inner and outer seals for the axles
13. Kill switch, starter button, and several other switches.
14. Staz works Kit and indicator lights.
15. Several Jegs Fittings can be seen in pics.
16. Battery Box
17. Aluminum transmission shield. you may or may not use.
18. Steering wheel.
19. Wilwood Calipers
20.ATL Fuel Cell
21. Custom Headers
Im sure Im leaving several things out but the pictures and the buildup post should answer most questions.
This is not a distressed sale. I have purchased another rig and cannot justify them both. If you have thought about building one…. Here is your opportunity to save a ton! $25,000obo. May consider partial trade but it had better be something good. Call or Text Chance 256-303-9858 Danville AL
Chevy 6.0 with 58k
Atlas II 3.8
8 Lug Conversions
42’’ Irok Stickys
2.Trans Cooler
3. 2 Jegs 16'' Fans
9. Belly Pan.
16. Battery Box
18. Steering wheel.
20.ATL Fuel Cell
21. Custom Headers
bump for a ***s rig!
