Barnes 4wd
- Joined
- Aug 29, 2013
- Messages
- 399
- Reaction score
- 0
Ultra 100 Radius Arm Brackets
Radius Arms are simple and they work! This bracket will allow you to mount a heim joint where the upper control arm on a radius arm suspension mounts to the lower arm. Having a heim joint in this location is critical to elevating the inherent binding issues of a radius arm. The brackets are made to weld onto a lower control are with a two inch outer diameter and give you a two inch inside mounting width with a 5/8” bolt hole. These are made from 3/16 100,000 min yield steel and are sold in pairs.
