Octane tech
I don't know much about motors but I can tell you that 93 octane with 10% ethanol. Is just 91 octane pure gas with ethanol to boost it up to 93. Dunno if that helps.
Sent from my SM-G900V using Tapatalk
Octane Facts
• Knock occurs when cylinder pressures are high. It is normal for an engine to ping a little at full throttle
because cylinder pressures are very high at full throttle. Engine knock, however, should not be ignored
since it can result in serious damage to the engine.
• High octane gasoline burns slower than low octane gasoline. The slow burn prevents engine knock when
• If your engine runs well and does not knock or ping on low octane gasoline, there is no advantage in
switching to higher octane gasoline.
found here: http://forum.ih8mud.com/threads/high-octane-fuel-vs-low-octane-fuel-facts-and-myths.160442/
^^^ True dat! 99% of the people have no idea about gas, I get cracked up when I hear someone say if you put racing fuel in your car, it could burn it up! The higher the octane, the slower it will burn and harder to ignite.
When i used to run the mud boggs guys would kill me buying cam2 and putting it in a stock engine, they swear it runs better. Haha
This is for a daily driver / inline 6 / twin turbo car with a computer tune.
I've ran the 100% gas that was 91 octane and now the 93 w/ethanol. The 93 felt better/smoother which I figured would the opposite.
I plan to run a meth injection setup later.
muddinmetal said:
If you can get good consistant quality e85
I buy mine from a local gas station 30 gallons at a time and check it there has only been a few times I have had to blend it to make it correct only trouble I have is this time of year when they start mixing it for winter
What motor you runnin Tony?
I think it depends what you're going for as well. Power or milage.
Ethanol (such as E85) has a higher octane rating (push more boost or compression).
But ethanol is less energy dense than gas. (takes more of it to do the same work). 1 gallon of E10 has 96.7% the energy of 1 gallon of pure gas, according to this:
http://www.afdc.energy.gov/fuels/fuel_comparison_chart.pdf
There's other stuff inlolved too like the volumetric efficiency of forced induction vs NA, but whatever. That's apples & oranges.
