red94yj
Selling a "lightly used" ord magnum box that was originally behind a turbo 400 and a Chevy 205. Got a Reid case for the 400 and rarely used low low so the magnum box was removed from drivetrain. The Jeep was a new build when the magnum box was installed so the unit only has 335 miles on it total.
Adapter is for a Chevy turbo 400
Weight is around 35 pounds and is 6.125" long. This box as well as the input shaft is for big bore 205 cases. If you have a small hole case, you can bore your case to accept the larger bearing. Bolts directly to GM/Dodge figure 8 205, GM round pattern 205 or Ford 205 with no adapters.
Price: sold
Located in Trussville Alabama 35173
I have no problems shipping anywhere. The box weighs around 35 pounds so it may be a little pricey.
Price: sold
