Orbital power beyond.
throttlejunkie
Cleveland, Ga.
Anyone used the 5 port steering valve? Ive done some searching, if your not using the power beyond port, I see you can just T it into the return. Anyone done this, any issues with low pressure hose fittings like most returns have while combining the two lines?
I ran one way back in the day. At the time just getting into full hydro steering I had some company make all my lines and I believe they just plugged it. Would of just been a SAE o ring Allen head plug. May not be much help to you because I'm not exactly 100 percent positive.
No when I first went rear steer I just had my krc pump but it was way too slow. So then I redone the setup and run the krc pump for the front and a stockish art factory ford pump for the rear. Both steer perfect and fast like this with no problems going on 5 years now.
