PCR #003
Bebop
SOLD !
Partially Committed Racing 50" 1.75" chassis, with 0.188" wall in subframe, impact areas, and A, B, and C pillar, rest is 0.120" wall
Mixture of 1.5", 1.25", and 1.00" X 0.120" wall for rest of chassis. Twisted Customs TJ hood/grill, alum skins, and full 0.125" alum roof
5.3 with car intake, Howell wire harness and ecm, alt relocated to pass side, Griffin radiator with fans wired to ecm. Sanderson headers, ceramic coated.
700R4 trans, RMVB, Art Carr shifter. B & M super cooler with fan, wired to in cab switch
4.3 atlas
Front axle :
- Rockcrusher HP 60 centersection with Spidertrax steering knuckles
- ARB air locker, 5.38 gears
- Spidertrax ultimate unit bearings, 5 X 5.5 with 5/8" studs
- CTM 300M 35 spline inner shafts, CTM u-joints, and Spidertrax 35 300M spline outers
Rear axle :
- Spidertrax housing, with full backbone/truss
- Mega High 9 center section, 35 spline spool, Spidertrax 300M full float shafts
Brakes :
- Spidertrax hats and 14" rotors, Wilwood 4-piston calipers.
- Rear electric cutting brakes/line lock on in-cab switch.
- Willwood rev swing pedal, with dual ¾ master cylinders.
Suspension :
- Radflo 2.0 coilovers, 14" front, 16" rear, tuned by Phil Licciardi
- Lowers links are Spidertrax 2" heat treated chromoly (really light and really stong)
- Upper links are 7075 AL
- Branik sway bar
Walker Evans wheels, 39" BFG Krawlers, great tread
Warn 9.0 RC front winch. Warn rear suck down winch. Both controlled with in cab switch. Both have synthetic rope.
PSC full hydro steering, single ended ram mounted behind front axle. Great steering angle.
All alum interior, with doghouse, and trans tunnel, 2 cup holders, rear firewall
Autometer gauges water temp, trans temp, volt, and oil pressure.
Optima yellow top battery, fuel cell, Swag off road action packer hold down for storage, and additional tray at back of buggy for storage/cooler
Mastercraft seats (driver seat has small tear in seat cushion, see pic), PRP 5.2 harnesses
Slight damage to front driver side hood (see pic).
Buggy is light and very stable. About 3800 lbs. Approx. overall height is 70", with 18" belly. Wheelbase 110".
Always been well maintained and driver was not a "rock bouncer", if you know what I mean.
NO TRADES.
Listing for a friend who doesn't have social media.
$42k OBO
PM me for questions / contact. Please don't waste his time.
