Barnes 4wd
- Joined
- Aug 29, 2013
- Messages
- 399
- Reaction score
- 0
Pinion Guards from Barnes 4wd
Ever heard the old saying that "an ounce of prevention is worth a pound of cure?" Well let me introduce you to 8 pounds of prevention! The Barnes 4WD GM 14 bolt Pinion Skid is intended to be just that, this product will keep you from ending a weekend of wheeling early. Most of the time when you get your pinion u-joint yoke on a rock, your u-joint has had it and so has your forward momentum. Now you can wheel with confidence knowing that one vulnerable area of your rig is protected from the nastiest rocks. The Barnes 4WD 14 bolt skid is laser cut from 3/8" plate, and shipped welded.
GM 14 Bolt Pinion Guard $44.75
http://www.barnes4wd.com/14-Bolt-Pinion-Guard_p_197.html
Ford 9" Pinion Guard $35
http://www.barnes4wd.com/Ford-9-Pinion-Guard_p_219.html
