PRICE DROP!!
1982 Jeep CJ 7 Rock Crawler for Sale
$11,000
Clean / Clear ***le
Fuel injected AMC 360 with long tube headers.
NV4500 Transmission with hydraulic clutch conversion (clutch has about 5 rides on it)
Atlas II Transfer case with upgraded shift forks and larger front output.
Blue Torch full width kit front and rear with 2.5 inch BDS leaf springs with Bilstein shocks.
39.5/15 Super Swamper Boggers (rear are cut) on Allied Rockathon Beadlocks 8 lug wheels.
Front Axle- Dynatrac High Pinion passenger side drop.
1.25€šš DOM Drag link with heims.
1.5€šš DOM .250 wall tie rod with heims.
35 Spline chromoly axles, inner and outer, with 1480 Axle joints.
Detroit Locker, with 4.10 gears. 1410 yoke.
Axle has approx 3,000 miles on it.
Setup with crossover steering however, knuckles have been tapped for high steer if you want to convert.
Steering is powered by a redneck ram box with a 1.5€šš bore x 8€ššstroke PSC cylinder. Steering cooler sits in front of the radiator.
Rear Axle- Dana 60 full floater bored out for 35 spline chromoly axle shafts. Full carrier spool, set up with 4.10 gears. Rockcrusher diff guard.
Driveline- Front driveshafts is a double cardan style shaft with a flange style mount at transfer case. Rear drive shaft has 1410 joints at both ends.
Roll cage is primarily 1.75 DOM that is tied into frame at 4 points. Corbeau baja suspension seats are tied into cage.
On board air via Sanden style compressor.
RCI 2171a 17 gallon fuel cell with 2 walbro pick ups in tank, Motobilt fuel cell mount.
Warn 9500 winch with synthetic rope.
Also have full windshield.
20 inch LED light bar, police siren, CB. Swag offroad 24 Gallon action packer Dimple Died Baja Bin.
Jeep has always been garaged.
For more information,
[email protected] 770-367-1392
Please contact Brian
770-367-1392
$11,000
Clean / Clear ***le
770-367-1392
