Sold/Expired PRICE DROP - 2 front 2.5 ton Rockwell axles $2600 for ALL
muddysmurf
Member
Alabama
2 front 2.5 ton Rockwells already set up with mohawk pans and pinion brakes. 1 has a spool, the other has the "Orb of Traction" super-welded spiders that are basically a giant ball of steel. One is missing a short side inner shaft but those are cheap. One housing is slightly bent but the two Rockwell guys I know both said there's no way it's bent enough to hurt, no friction at all when pulling shaft.
Axles are completely disassembled and sitting on a pallet right now at a buddy's shop. Every bracket and tab has already been cut/ground smooth off axles. Hubs are not flipped yet but that's easy to DIY.
Also have steering components:
2 - Surplus Center 2.5"x10"x1.5" double-ended rams
4 - Surplus Center 3/8" hose barb to SAE 6M 90 degree elbows
1 - PSC orbital mount for 1.75" tubing
4 - PSC Rockwell steering arm taper adapters
1 - PSC rear steer directional valve
1 - PSC steering column (.75" stub tp 4.75" length)
4 - RuffStuff 7/8" left hand rod ends with jam nuts and weld-in tube adapters
4 - RuffStuff 7/8" right hand rod ends with jam nuts and weld-in tube adapters
1 - 13105 trans cooler tube and fin 22,500 lb
1 - Overson Rockwell bible book
1 - steering cooler tube and fin style
another orbital valve mount for 1.75" tube from Bluetorch Fab
All steering components are brand new.
Price - $2600 for all of it. Close to Birmingham, AL.
Re: 2 front 2.5 ton Rockwell axles
More pics...
Sell just the rear steer control valve?
We're trying to keep it all together hoping everything will sell quicker.
Thanks!
is this everything to setup a full front/rear steer rockwell system? If not what is needed to make that happen?
You'd need four 7/8" clevises for the ends of the rams, I was gonna have BuggyMike from Tarrant Hydraulic make them for me but never got around to it. I've seen some online though. Also need 4 short pieces of DOM for the short tierods and a hydraulic pump and hoses.
If u were interested in splitting it up I'd b interested in the heims
Very interested phone number to contact
Gonna try to sell it all as a full set if I can.
Just sent ya a PM. Sorry about my crappy keyboard, first PM had an incorrect phone number in it so I re-sent it with the correct number.
If u decide to split up I would be interested in one of the steer axles
I am interested if you still have all this stuff. Please call or text at 828 310-6179 Shane. Thanks.
Interested in anything in trade (partial or full)?
I have a rig, hp60/10.5" out of an '04 Super Duty, C6 trans, and some other stuff. I know it's a long shot that I'd have exactly what you're looking for, but it's worth a shot.
Either way, free bump.
The axles and everything else is sold guys. Seller is a friend.
