Sold/Expired Price reduction 2016 Recoil bouncer buggy ls3/scs gearbox ripper
snopro66
Member
;DRecoil buggy for sale (rock bouncer)
LS3 6.2L Texas speed spec for 600hp , corvette engine control ecu throttle pedal throttle body
Ceramic coated 180 deg headers and side pipes
Super fast hydro steering
Turbo 400 with manual valve body 4500 stall
Plate cooler
SCS gear box (transfer case)
14 bolt rear 4:10 gears
Dana 60 HP HD big tubes and knuckles off newer super duty RCV CTM axles
All flanged heavy duty high angle drivelines
43” swamper stickies on Raceline FORGED double bead locks (wheels)
King coil carriers and bypass shocks front and rear
7075 aluminum links
Led light bar
Edge engine monitor
Sway bar
This buggy is fresh only ran a couple times. hasn’t even been flopped yet. Runs strong and works really well
Asking price is $49,000
call 231-645-6196
https://youtu.be/YFR1XEvgjpc Read Less
Re: 2016 Recoil bouncer buggy ls3/scs gearbox ripper
muddinmetal said:
I have no money, but I am curious what gears are in the case.
I going off of memory which isn't that good. But I think they are 3:3 gears. SCS Case has quick change gears so its easy to change to any gearing you prefer. you can even swap the same gears side to side for different gearing
Bump ???? More of this buggy in action https://youtu.be/IhPg9xwaOvs
OBO Anbody? Great Unit here. Unfortunately I don’t have time to use it
