Sold/Expired Profender Air Bumps $139
Profender
Profender bumpstops help you use all of your available suspension travel. Profender bumpstops feature a 1 ¼” shaft and a 1 13/16” high flow piston for superior bottoming control. We use a high pressure Schrader valve with a gasketed cap to keep out dirt and moisture. Profender bumpstops are fully rebuildable and tunable with simple hand tools.
We offer 3" travel with a open length of 13.42" and a closed length of 10.35". and a 4" travel with a open length of 15" and a closed length of 11". The maximum rated pressure is 400 psi.
Profender bumpstops are fully rebuildable and adjustable by adding or removing the internal shims and adjusting the nitrogen pressure.
Our mounting cans are the beefiest cans on the market. They are made from 3/16" steel and have 2 pinch bolts. They are sandblasted to ensure a smooth and even finish.
3" or 4" travel 2.0 bumpstops are $139 each, and the mounting cans are $26 each.
Check out our full line of products at www.profenderusa.com
no complaints at all no serious flights buggy is sold so i took it kinda easy on it but i will be in contact for bumps and 2.5 coil overs on the new buggy
