rock head 44
- Joined
- Feb 28, 2011
- Messages
- 265
1991 jeep wrangler back halved tube fenders 4 linked hydraulic steer front & rear 1" body lift 1" raised motor mounts alum radiator rci 15 gallon alum fuel cell with efi pump summit racing seat g-force 5 point harness
engine
4.0 6cyl efi
tranny
ax15 5 speed
transfer case
atlas 4.3 big front out put 1350 yokes
front axle
1979 ford hp 410 gear Detroit locker yukon cromoly 4340 axles 35 spline inner & outer yukon joints rock crusher drive flange 1350 yoke 1/2 ton brake set up solid diff cover
rear axle
1979 ford hp that's been centered up 410 gear spool yukon cromoly 4340 axles 35 spline inner & outer spicer joints rock crucher drive flanges 1/2 ton brake set up solid diff cover
suspension
aluminum links
top 1.5"D 36" L 3/4x5/8 rod ends
bottom 2"D 42"L 7/8x3/4 rod ends
5.5" pro comp tj springs
14" procomp 9000
10,000
423 413 9071
engine
4.0 6cyl efi
tranny
ax15 5 speed
transfer case
front axle
rear axle
suspension
aluminum links
14" procomp 9000
10,000
423 413 9071
