Rock Crawling Forums
propane
Reply to thread
Message
<blockquote data-quote="mark" data-source="post: 1347412" data-attributes="member: 16354"><p>Propane going from liquid to gas gets VERY cold, short of Moab in the summer doesn't matter what the temperature is out side. The vaporizer NEEDS hot water running through it to keep from turning into a popsicle, and that can make for a very shitty day.</p><p></p><p>BTDT. Make sure the vaporizer is located low enough to be easy to burp any air out of the coolant system, and defiantly not be the high point. Make sure your cooling system is in good shape as well, if you over heat or burp air, you loose water to the vaporizer, your stuck on the trail.</p><p></p><p>BTDT.</p><p></p><p></p><p>Internet search will teach you this.</p></blockquote><p></p>
[QUOTE="mark, post: 1347412, member: 16354"] Propane going from liquid to gas gets VERY cold, short of Moab in the summer doesn't matter what the temperature is out side. The vaporizer NEEDS hot water running through it to keep from turning into a popsicle, and that can make for a very shitty day. BTDT. Make sure the vaporizer is located low enough to be easy to burp any air out of the coolant system, and defiantly not be the high point. Make sure your cooling system is in good shape as well, if you over heat or burp air, you loose water to the vaporizer, your stuck on the trail. BTDT. Internet search will teach you this. [/QUOTE]
Verification
Post reply
Latest: BIG_BLAZER86
Today at 12:40 AM
P
YouTube of the day
Latest: paradisepwoffrd
Yesterday at 8:21 AM
Cash LeCroy Illness
Sunday at 2:58 PM
Saturday at 3:52 PM
Latest: Piros 1
Saturday at 2:27 PM
propane
