I bought this last year to try my hand racing in the Dirt Riot Series. Its built for the trail modified class. I was able to finish 1st place in the chocco and 4th at grayrock. It has a good parts list however there are some minor things wrong and its been beat up pretty good. I took it on a trial ride last month to chocco and it did fine. It rides and jumps pretty good.
Issues- front axle is tweaked it has negative camber which believe it or not helps the jeep steer better and the
rear main leaks. Also one coil spring is a little funky
This is a race jeep so theres no glass the front windshield is plexiglass. Theres no dash however I did leave the heater stuff so you wont get cold in the winter. The cage/seat combo will be tight for someone 6' and taller.
Anyhow heres the specs, everything is in working order may not look the best though.
1997 Jeep Cherokee
- 4.0L with 133K on the ticker
- Throttle Body spacer
- NP231 with SYE
- Identical drive shafts front and rear. Both are front shafts.
- K&N air filter
-Ironman engine brackets and mounts
Suspension
- King 2.5" 10" Reservior front shocks
- Bilstein 2.65" 14" Quad Bypass shocks in rear
- Custom built leaf spring perches
- Deaver Progressive 280 front 5.5" lift springs in front.
- Rubicon Express Superflex 3.5" leafs out back with 2" shackles.
Rear Axle is a Chrysler 8.25 29 spline
- Welded and plated spider gears in rear.
- OEM shafts
- Upgraded brake shoes.
- Nitro 4.88 8.25 gears.
- IronRock 8.25 truss.
- Tube diff guard
Front Axle is a Dana HP 30
- Revolution 4.88 gears
- Alloy USA complete chromo axle shafts and ujoints.
- Arctec truss
- Arctec C gussets
- Warn diff guard
- Currie johnny joints for UCAs
- Detroit TrueTrac mechanical LSD
- Currie Currectlync drag link
- Custom Ironman4x4fab aluminum tie rod with Currie TREs
- Ironman4x4fab trackbar
- Rusty's trackbar bracket
- Durango steering box
- 4 pass aluminum PS cooler
- 4 pass aluminum Transmission cooler.
- Full unibody stiffners front to rear
- Custom built 2x6 (clayton like style) long arm/transmission crossmember. Center can be removed for servicing trans/engine without removing suspension.
- 2" 1/4" wall custom longarms in front with bushings on both sides
- Summit racing racing seats
- 5 pnt Harnesses
- 8 pnt cage tied into sliders @ points around driver/codriver
- Custom sliders
- Custom rear light boxes with LED lights.
- Custom rear bumper
- Custom front bumper
- Smittybuilt 10K winch
- In cab winch controls
- ELS rear spot lights
- Yellow LED light bar on an aluminum bracket (racing light)
- Military style latch box for tools and parts in rear
- 4 Allied bead locks
- BFG KM1 35" MT's
- Hi Lift jack
Let me know if anymore pics are needed.. Located in Middle ga will help with delivery. Price is obo.. Not really looking for trades. 3500 obo
1997 Jeep Cherokee
- NP231 with SYE
- K&N air filter
Suspension
- OEM shafts
- Tube diff guard
- Arctec truss
- Arctec C gussets
- Warn diff guard
- 5 pnt Harnesses
- Custom sliders
- BFG KM1 35" MT's
- Hi Lift jack
