Sold/Expired railbuggy Berrien Warrior 2 seater
woodsrail1915
Member
Posted: Tue Aug 16, 2011 10:16 am Post subject: railbuggy Berrien Warrior 2 seater
hydraulic steering â€" needs orbitor valve and pump but back on it
• Fox coil overs with external reservoirs 12” travel, Tweed design front arms 4 inc x1 ½ 2” spindles 4 wheel disk brakes CNC petals, CNC cutting brakes full stainless brake lines front to rear
• 6 rib tranny with 538 ring and pinion original super dif 930 CV’
• Rear suspension 2 by 3 box arms from Drews off road firestone air bag works very well
• Fuel system Holly fuel pump Full braided stainless fuel lines Fuel pressure regulator with earl fuel filter Water separator End line auto meter fuel pressure gauge
• Engine
• 1915 engine think the thrust bearings are out on the engine
• Parts on the engine
• Full MSD distributer with MSD blaster coil, 6 al box with chips
• Dual Webber 44 (the original), CB performance dry sump oil system, also with a remote oil filter, and oil cooler, all the oil lines are braided stainless, with A and N fittings
• CB performance o 44 heads
• Alternator
• Aluminum valve covers with a and n fittings tig welded in them for the vents
• After market rocker arms
• New fly wheel
• Valve covers and the oil fill are all braided stainless for the vents
• Tires and rims 5 lug
• Firestone 8 ply tractors
• 31/15/5/15
• Rear rims are two piece aluminum
• Front 7/15 v tread tractors
• Also 2 piece aluminum rims
• Full fiber glass body
• Full skid plates and roof 5000 or trade for a tube buggy 4x4 ask for scott 859 866 2722
Back to top
