SSSMOKN97
Active Member
- Joined
- Sep 15, 2015
- Messages
- 27
Ladder bar/antiwrap bar for YJ/CJ spring over. Or anything else SOA. New Barnes 4wd 2" poly joints at axle end for 5/8" bolts. New Barnes 4wd 3/4"x3/4"3 piece heim on frame end. Made from 1 1/8"x .250 wall DOM. Ends tapped. No weld in bungs $150.
Advance adapters bellhousing. Jeep 4.0L to CJ T-4, T-5, T-176, T-150, and will also fit Ford NP435 4 speed. Have the clutch Fork and a new never used center force 11" clutch 10 spline 1 1/6" input for above listed transmissions. Bought it lightly used and never used it. Part number 712569 if you want to look it up. $250
Factory LS2 exhaust manifolds. Came from 05 GTO. $100
Text 3343919513 Located in Prattville AL
