Sold/Expired RCI 15 gallon fuel cell ***small leak***
tonybolton
Bypass Crawler
351
Lenoir City, TN
This is the 30x9x12 (12 high...9 deep) version.
-8 bungs for vent...pickup....return. Has rollover valve in vent.
Didn't feel like patching so jus got a new one.
There are 2 super duper small leaks in the weld on one side. One about 3" from top and another about 3" from the bottom. The close up pix I'll post are of the leak area.
Maybe you got a buddy that'll tig it back for a bucks?
Also has GM 0 - 90 ohm sending unit....but wasn't used.
Again...there are 2 tiny pinhole leaks in a weld seam on this. Just want to be clear.
This cell was mounted using straps....not the tabs on the bottom. Those had been cut off.
50$ picked up in Lenoir City TN. ....ph/text 865-363-6664.
I got one of these tanks and it did the same thing! JB weld makes a epoxy that is oil, gas, waterproof, I cleaned the spot real good and scuffed it real good with 80 grit, let it sit 24 hours, so far so good.
Send it to RCI and they will fix or replace it free.
