Sold/Expired Rebuilt 5.3 in the process.
custompowr
Member
I have a 5.3 out of a 2002 silverado for sale. Engine is in the process of being rebuilt. Engine has the deck surface cut and trued and the cylinders have been bored .040 over with new pistons, pins, rings and bearings. Includes new oil pump and ARP rod bolts. A new cam retainer plate which holds a new Comp Mutha Thumpr cam. New LS-7 Lifters and GM plastic lifter retainers. New Comp Cams beehive springs, locks and retainers hold the new larger intake valves. Heads have fresh valve job and and have had some port work in the chamber and ports. I have not cut the heads yet so the desired compression ratio for the application can be achieved. New head bolts will hold the heads down. All new gaskets and seals. This engine also has exhaust manifolds, all the sensors, a cut wiring harness and a reflashed ECM to go along with it. All work performed has been professionally done at my shop in Knoxville Tennessee. Will post pics asap. $3750
Some pics
Also includes air conditioning compressor, alternator, power steering pump, water pump and all brackets. This is a complete engine.
The engine will be complete and ready to bolt in and go. Have just been waiting to see if someone wanted it for a buggy, then I could surface the heads and add some compression to it.should make around 375 HP if not more.
