hottie_wheels
New Member
- Joined
- Nov 19, 2013
- Messages
- 3
'73 Early Bronco Stretched Half Cab: $9,000 REDUCED TO $8,000
1973 Ford Bronco wagon custom fabricated into a half cab
Runs great
Clear ***le
Garage kept
16" body stretch adding tons of much-needed room within the cab
351 Windsor
Rocker panels
Hydroboost disc brakes
Dana 60 front axle
Sterling rear axle
NP435/205 Transmission
Gearbanger
Hand throttle
4.56 gears
Front and rear lockers
Custom-machined ring and pinion set
Shaved differential for extra ground clearance
Custom front suspension
Aluminum extra capacity fuel cell mounted behind the bulkhead
Aluminum alloy radiator
MSD
Custom exhaust
Tons of flex
BC Broncos steering shaft
6" coil springs
57" leaf springs
Rear shock hoop
Recently replaced floor pans
Wild Horses 4x4 Silverbacks Fender Flares
James Duff tube trail doors with lift off hinges
Alloy wheels (painted black)
Nice front and rear bumpers
39.5" Super Swampers
Newer seats
5 point harnesses
Push button start
Yellow top battery
Countless custom fabrications
Brand new full in-cab roll cage (needs to be installed)
http://okaloosa.craigslist.org/cto/4200580354.html
[Feel free to email [email protected] or text (850)896-7703 with any questions or requests to see this beast in person
http://broncograveyard.com/images/readers/image_39674m.jpg
http://broncograveyard.com/images/readers/image_39676m.jpg
http://broncograveyard.com/images/readers/image_39675m.jpg
http://broncograveyard.com/images/readers/image_39678m.jpg
http://broncograveyard.com/images/readers/image_39679m.jpg
http://broncograveyard.com/images/readers/image_39680m.jpg
http://broncograveyard.com/images/readers/image_39681m.jpg
http://broncograveyard.com/images/readers/image_39682m.jpg
http://broncograveyard.com/images/readers/image_39685m.jpg
http://broncograveyard.com/images/readers/image_39684m.jpg
Runs great
Clear ***le
Garage kept
351 Windsor
Rocker panels
Dana 60 front axle
Sterling rear axle
Gearbanger
Hand throttle
4.56 gears
MSD
Custom exhaust
Tons of flex
6" coil springs
57" leaf springs
Rear shock hoop
Newer seats
5 point harnesses
Push button start
Yellow top battery
