Sold/Expired RELENTLESS rockbouncer buggy Price drop
Lickliter21
Lawrencburg Ky
Had it for sale last year and decided to race it anther season.
2013 tube buggy "RELENTLESS"
Finished building this buggy march of 2013.
Raced 2 races with SRRS 4 ARC races and 4 with AOP series. Finished pretty good at all the races. Lots of trail riding also. Buggy flat works and goes great. Fits almost any size driver. I'm 6'3" 325lbs and fit great ride all day comfortably. Even had it raced in powderpuff a few times and she was 5' something and still could see pretty well and reach the pedals with ease. Buggy was built to be tough and reliable
1.75 .120 DOM chassis
All tabs and brackets on the buggy minimum of 3/8 steel.
All aluminum 3/16 floor and fire wall
PRP Competition High Back Seat
That are +3 +6
PRP 3" padded seat belts
2 brake pedals and master cylinder for front and rear brakes.
Quick disconnect steering wheel.
All waterproof rocker switches.
From otrattw.
Small storage box between the seats.
Red top optima battery.
Fire extinguisher easy to reach while belted tight.
All fuses and wiring connection made with heat shrink connectors.
2004 6.0 Chevy LS engine cut down wiring harness. 799 heads and GM hot cam. custom dyno tune. Intake turned around
400 turbo trans with red alto racing clutches 4500 stall, manual valve body. Newly rebuild. large cooler with built in fan.
Ford 205 with 32 spline inputs and outputs. 1350 U joints 1410 rear Joint. Forged yokes. Bolted to the 400 with factory adapter.
43sx stickies and 17" steel beadlocks. Tire have a few races almost no trail riding time on them.
14 bolt front RCV axles 5:13 gears with spool. 1.25 thick high steer arms. 1.25 hiems for tie rod ends. 3/8 thick diff cover.
14 bolt rear disk brake 5:13 gear
2.25" 7075 WOD lower links with 1.25 hiems
2" 7075 WOD upper links with 1.25 hiems
2.5" FOA 18" coilovers tuned with new springs
Aluminum radiator with large cooling fan. Fan is automatic and switch override. Radiator is new. Driveshaft went through the other one
Aluminum fuel cell holds 7 gallons. No foam.
Walbo fuel pump corvette regulator. All stainless steel braided hose and AN fittings.
Buggys been worked hard this year keeps coming back for more. Tubbing still in good shape. Does have a few dents but no flat tubes. Still safe and ready to race or trail ride all day comfortably.
3980 LBS
70" tall
21" ground clearance
33,000 or best offer
May take partial trade on a side by side
Call or Text 1-502-680-3219
Thanks Dean
damn thats cheap. Shouldn't last long at that.
