Sold/Expired Rock Crawler
01superdave
New Member
One seater tube chassis, 4.3 Chevy V6, Turbo charged, 350 turbo transmission, shift kit, 3500-4200 stall convertor, toyota transfer case, 4.7 gear, chrome moly output shaft from Lonfield with lifetime warranty, transfer case has never had any problems, Dana 60 Chevy front end with 35 spline stub axles, solid drive flanges on all 4 corners, dana 60 Ford high pinion rear axle has yukon 35 spline chrome moly axles (inner and outer) 10 yr warranty. Rear chunk has been centered for perfect drive shaft angles, both differentials are welded, 44" TSL superswampers cut and grooved, 15X8 Allied Bead locks (32 bolt), 4 wheel disc brake, Wilwood pedal assembly, PSC power steering pump, has 2 coolers for hydraulic steering buggy has rear steer, trany has B&M super cooler, 19X22 aluminum radiator, 16" 3200 CFM fan, runs very cool, Premier power welder installed, perfect shape, 16" brand new Fox coilover shocks, front and back, Kirkey seat & 5 point harness, detachable steering wheel. Buggy is about 5 yrs old. No trades... $17,000.00 OBO Please call 423-280-9534- David.
[attachment deleted by admin]
boys this biggy will flat out get with it ! i have seen it climb in high gear and still be blowing the tires off . good luck with the sale SUPERDAVE
