Sold/Expired Rockwell Tube buggy SOLD SOLD
harperc
Member
SOLD SOLD
Posting for a buddy please contact him at number below.
Turn key full tube chassis crawler for sale only $12000.00 OBO (NO TRADES) in Middle TN. Rig has the following parts or components:
1. 117 " wheelbase full tube chassis built out of 1 1/2'' DOM and HREW mix, cockpit is built for bigger people and has plenty of room.
2. Old school 383 small block Chevy (3 rides on rebuilt 882 heads) on propane with Impco components.
3. Completely rebuilt Turbo 350 and with engine braking, manual valve body and 1800 stall converter controlled by a Billa Vista modded B&M shifter (3rides on trans).
4. Twin sticked 205 transfer case, I have a complete LOMAX 205 case and all of the components to build it up for an additional $2200.00 (not included in asking price).
5. Two Rockwell steering axles with pinion brakes, (has dual pedal master cylinder for front and rear digs) that have the hubs flipped with all right hand studs, front axle has TSC
Hyd cylinder for steering,rear axle is locked out. Axles need boots and inner seals replaced.
6. Front and rear Bilstein remote reservoir coil overs with Hyper coils, Ballistic Fab 4 link towers and frame brackets with Ballistic Fab1 1/4'' rod ends on 2 1/2'' x 1/2''
wall lower links and 1 1/4'' upper links with 1'' rod ends. Limit straps on all 4 corners with rubber bumps front and rear.
7. 19.5" x 44" x 15" grooved TSL Boggers on 24 bolt MRW bead locks, (95 % tread) no cuts or plugs hold air perfect.
8. Has electric engine cooling fan and separate fan for transmission cooler both of these are on toggle switches.
9. All electrical components are on separate switches with circuit breakers, has master disconnect switch in cockpit.
10. Kirkey aluminum seats with custom pads, RCI 3'' 4 point latch type harness, quick disconnect steering wheel.
11. Comes with 2 see through fiberglass propane tanks and various extra parts u-joints, yoke flange for diffs,high steer arm and steering cylinder.
This is just a good all around trail rig that works well and has never let me down, call or text 615-478-9982 for any questions you may have, Rig is located 30 miles east of
Nashville TN in Lebanon.
Re: Rockwell Tube buggy $12.000 OBO
Do you still have the buggy for sale? When you say obo, what's the least you are willing to take for it? Aint no point in haggling over the sale price. Just give me your rock bottom dollar figure and we'll go from there. Thanks
Please call the number listed in ad. Not my buggy just posted for my buddy. Thanks
TTT anyone looking for a great rockwell buggy needs to go look at this rig.
