Sold/Expired Rockwell Wheel brake Setup and Pat Parts pinion brake
toreadorranger
I have a set of Wheel brakes for steering 2.5 ton rockwell. Uses wilwood calipers and aluminum spacer for the rotors that is sandwiched between the lug studs and the hub, caliper mount uses the Spindle studs, has to be run hubs out. Comes with rotors, caliper mounts, calipers, longer studs and rotor mounts $500
Pat Parts Pinion brake setup, new in the box. Includes the rotor but needs a caliper (uses 86 Toyota pickup caliper) $80
