Sold/Expired Rockworx 4 Seat Buggy - 383 Stroker / 300M / Atlas all the goodies..etc...
leetevo
Active Member
SOLD!
I’ve decided to list my 4 seater Rockworx / Bentfab buggy for sale. I’m currently building another comp buggy and this one needs to go. I’m open to trades + cash for a wide variety of things. Feel free to PM any questions and I’ll send you my number to chat. I picked this up and June 2015 and just redid everything (motor / trans / axles etc..) this winter. I’ve had a blast owning this and it has done some of the most challenging trails in AZ and surrounding areas. Pictures are current as of today and with the weather heating up I don’t expect to be wheeling it for a while not to mention I can’t bring myself to mess up the new panels / paint!
Builder: RockWorx & Bent Fabrication
Clean ***le: The buggy does has a vin and is ***led as a CJ7. It has blinkers, brake lights and removable (lexan) windshield and is street legal.
Open to Trade: Yes. Pretty much open to anything. Moon buggies, JK’s, pre-runners wakeboard boats, RZRs etc… I also have lots of spare parts that can be worked in to the deal if wanted.
DRIVETRAIN:
Front/Rear Suspension Type: 4 link Aluminum
Front/Rear Shock: 16” Fox Coilovers
Rear Sway Bar: Sway-a-way
Front Axle Housing: SOLID fabrication Hi pinion dana 60 (New in Feb) ( SOLID Center, SOLID Knuckles and SOLID C’s etc..)
Front Locker: Spool (New in Feb)
Front Axle Shafts: 35 spline Yukon (with spares) (New in Feb)
Front U-joints: Yukon SuperJoints (New in Feb)
Brakes: Hydroboost + Chevy Calipers (New in Feb)
Steering Components: PSC double ended ram Full Hydro. (PSCE pump, ram, reservoir and relief valves)
Rear Axle Housing: Balsitic FAB shaved 14B (New in Feb)
Rear Axle Shafts: 300M (New in Feb)
Rear locker: Spool (New in Feb)
Ring and Pinion: Yukon 5.13 gears (New in Feb)
Tire Make / Size: 39” BFG Krawler Redlabels (Only handful runs on them purchaced in Feb)
Wheels: 17” 8x6.5” Spyderlock beadlocks (5)
Body interior:
Panels: Bent Fabrication Aluminum (Will be brand new painted Red)
Skid plate material: MDF
Hood /Grille: CE - Fiberglass hood and Grille (Will be brand new painted Red)
Floors / Firewalls: Bent Fabrication Aluminum
Pedal Assembly: Wilwood / Bent Fabrication (Brand new in Feb)
Seats / Harnesses: Coubera
Electronics: Rugged Race Radio, Rugged Intercom, Aerometer gauges.
Lights Interior / exterior: Rugged Ridge and Vision X , LED Headlights and Rocklights
Fire Extinguisher:
Winch: Warn 9.0RC
Chassis:
Design: Rockworx
Chassis Materials: 1.75 x .120 DOM
Overall Wheelbase: 114”
Overall Length: 154”
Belly pan Clearance: 21”
Wheel Track Width: 86.4”
Chassis Width: 54”
Overall Weight Estimate:3500
Powertrain:
Engine: Chevy 383TB Stroker (new Race Heads in Feb)
Horsepower: 425+
Torque: 500+
Battery: Oddesy
Radiator: Griffin (New in Feb)
Air intake: K&N
Transmission: Built TH400 (new in Feb)
Transmission cooling: Deale (New in Feb)
Transfer case: Atlas 4.3S
Driveshaft’s: TAD .250 1350/1410
Fuel Tank: Aluminum with Warn pickups (new in Feb)
sorry not trying to steal your ad but what kind of pressure do u run in you bumpstops?
