cantrellzach
Engine
350 SBC Bored .040 Over New Rings & Bearings
Dart Pro1 Aluminum Heads Jessle Gold Series Roller Rockers
Small Camshaft
Holly Projection 4Di
Aluminum Radiator With Dual Electric Fans & Shroud
Transmission-Transfer Case
TH400
Shifts Great
HE MAN Machine Transfer Case Stand
NP205 32 Spline Input 32 Spline Rear Output 30 Spline Front Output
All 1410 Yokes & Joints
Case is Modified For Twin Stick Does Not Have Shifters
Axles
2.5 Ton Rockwells
Pinion Brakes
Mow-hawked Pans
U-Joint Shafts In The Front
PSC 3.0 Double Ended Ram
Links & Rod Ends
All Links Are 2" .250 Wall Square Tubing
All 1"1/4 Rod Ends Chassis Side is A Normal Rod End Axle Side Is A Trail Gear Creeper Joint
Double Triangulated 4 Link Front & Rear
Shocks
Front Has 14" Bilstein Coilovers
Rear Has 16" Fox 2.0 Air Shocks
Tires/Wheels
44x18x16.5 TSL's
TWF 12 Bolt Beadlocks With PVC Inserts & Rock Rings
Tires Are Probably 70% Tread
Body/Frame
Samurai Body
Some Of a Samurai Frame
Frame Has Been Plated In Some Areas
I Also Have a Set Of Like New Corbeau Baja SS Seats That I will let Go With It.
I Also Still Have The Doors That Will Fit With Some Motivational Speaking
This is a great trail rig I beat on it nearly every weekend very durable.
Would Like To Sell or Trade To A Bass Boat 13,500 OBO
Located In Woodbury, TN
Call Or Text Zach 615-542-5878
Small Camshaft
TH400
Shifts Great
Axles
2.5 Ton Rockwells
Pinion Brakes
Mow-hawked Pans
Links & Rod Ends
Shocks
Tires/Wheels
44x18x16.5 TSL's
Body/Frame
Samurai Body
