XtremeZuksOffroad
I have a 2.0 engine that is still running in the Tracker, it shows 100k but the engine is super clean inside so it may have been rebuilt and the compression is 200 in every cylinder. Im going to sell the engine with all the accessories, wiring harness, ecm and cluster for $1800 and we use the Trail Tough 2.0 kit when we do these swaps so if you want the kit and everything done it will be $3500 that will be the modified wiring harness, unbreakable motor mounts, aluminum radiator and electric fan, modified flywheel and electric fuel pump.
This engine is 130hp btw
