Samurai fender removal
Sandtrap1986
Puyallup
Is there some secret to getting this thing off ... I feel like I'm missing a screw or nut anyone have a drawing or something ....it's the left front/ driver side....also does anyone have a spare they want to part with .....
The fenders are actually spot welded to the front rad core support as a front clip assembly, the whole front clip comes off, then you access/drill the spot welds and remove the fender.
I was just about to say that a tree in the right place is the best way to remove a fender. You should have hit that tree just a bit harder :redneck:
You could remove the one bad fender if you have access to the spot welds from the inside by removing the junk on the inner fender, and grill assy IIRC...
