Sold/Expired Shocks, Limit Straps, Rod Ends, Aluminum Links, everything Suspension!
Thanks guys, if you have any questions give us a call and we will be happy to help you get what you need!
615.962.9135
Our link builder is a popular item! Order links in a variety of diameters, and any length! Drilled and tapped aluminum available.
Radflo Shocks and Bumpstops
Here at Wide Open Design we have had good lucking using Radflo products in our turn key and production line chassis. We have details on all the products on our website:
http://www.wideopendesign.com/Category/63/Radflo-Shocks-and-Bumpstops.aspx
7075, often referred to as "memory material," is an ideal choice for suspension links.
If you are tired of bending steel links then give these a shot.
1.5"-2.5" diameter bar
3/4"-16, 7/8"-14, and 1 1/4"-12 thread available
All links have wrench flats
All links are marked LH threaded
*These links are made to order. Standard lead time is 1 week.*
http://www.wideopendesign.com/Product/11145/7075-T6-Aluminum-Links.aspx
Limit Straps
Heavy duty quad-wrapped limit straps with the Wide Open Design "WOD" logo.
http://www.wideopendesign.com/Product/11631/Limit-Straps.aspx
Radflo 2.5" Non-Coil Hydraulic Bump Stop
Product Description:
SSID alloy steel tube body
Hard chromed and mirror polished A513 alloy steel rod
Rod Guide is CNC machined bronze, Teflon® coating
Combination Quad-Ring® and lip seal, rebuildable
Radflo aluminum Freeflo™ racing piston
Valving is Self-adjusting, velocity-sensitive deflective disc, consumer or factory tunable
Oil Radflo high-temp foam resistant suspension fluid
Nitrogen gas, 100-250 psi
Body Caps are CNC machined 6061 aluminum, welded or threaded stud Finish Clear cadmium plating
Consumer or factory serviceable
About
http://www.wideopendesign.com/Product/229/Radflo-2-5-Non-Coil-Hydraulic-Bump-Stop.aspx
Universal Antirock® Kit w/ Aluminum Arms
Currie now offers Antirock® sway bar kits in a universal form for those building their own custom rigs and rock buggys.
These universal kits feature a 32", 36" or 45" torsion bar length.
Arms are available in 17", 18", 20" long steel arms or 18" and 20" Aluminum arms.
Vertical links use a 14" long 1/2" x .20 RH/LH threaded rod that can be cut down to your desired length, and the necessary 1/2" x 20 thread heim joints, jam nuts, and tabs to weld to your axle tube are supplied.
Also supplied is the universal weld-in 1.75" x .095 wall DOM tube that is cut to the proper length to work with the torsion bar length, and the Delron bushings to support the bar in the tube.
These kits require fabricating for installation -- these are NOT bolt-on kits.
http://www.wideopendesign.com/Product/184/Universal-Antirock%C2%AE-Kit-w-Aluminum-Arms.aspx
