Sold/Expired Single 4.7 23 spline Toyota 550.00
Brian Brown
4.7 23 spline case new never ran case also has a heavy duty AA gear reduction case and multi mount flange 550.00 parts are in Columbia, TN. 615-405-8580.
Re: Toyota dual cases w/ twin sticks
$800.00 for cases with stock shifters
$925.00 for cases with twinsticks
Is the front case a top shift or forward shift?
do you have a twin stick kit with top shift case shift rails
Willing to split up if I have to crawl box which would be front case,adapter and hardware with shifter 450.00 all you will need to do is bolt your case to the back and rock out. Single 23 spline case with 4.7 gears and AA gear reduction case with shifter 650.00. Twin sticks 125.00.
Crawl box and adapter is gone still have single 4.7 23 spline case 650.00 and twin sticks 125.00!
Re: Single 4.7 23 spline Toyota t-case w/ twinsticks
Will sell t-case and twinsticks together for 700.00
Twinsticks gone case with stock shifter still available 600.00
